Need Suggestions. Want To Build Badass DA Suspension Setup
Old Oct 29, 2007 | 01:29 PM
Si2See's Avatar
Default Need Suggestions. Want To Build Badass DA Suspension Setup
Just like the title says, I am going to have my 93 gs-r painted at the end of feburary. In between now and then I want a better suspension setup.
I would like to spend in the neighborhood of $1500 or less.
Currently the car has-
Tein S Tech Springs
Tockico Blue struts
Ingalls Front Camber kit
I want a full coilover or stiffer suspension, my EF hatch handles like a champ but my DA feels like a boat.
What are some opinion on building a nice handling street car, that I will possibly auto-x a few times.
Old Oct 29, 2007 | 02:40 PM
hack_tc's Avatar
Cant go wrong with Ground Control Coilovers and Koni Yellow shocks. I also hear Buddy Club is really nice.
Old Oct 29, 2007 | 05:38 PM
Si2See's Avatar
i have had ground controls with koni yellows on a crx with the gc top hats.
I am wondering if I can achieve a stiffer, tighter ride with that setup or something like a tein full coilover, and also what to buy as far as sway bars, etc
Old Oct 29, 2007 | 05:46 PM
CarFreek's Avatar
Default Re: (Si2See)
No point in going with coil-overs, Unless your going to corner balance the car. And about 1 out of 300 people I've met have done so.
Old Oct 29, 2007 | 06:00 PM
suspendedHatch's Avatar
Default Re: Need Suggestions. Want To Build Badass DA Suspension Setup (Si2See)
Koni Yellows and some swaybars.
Struts are 90% of your handling and tokico blues are crap.
Old Oct 29, 2007 | 06:03 PM
Si2See's Avatar
Default Re: Need Suggestions. Want To Build Badass DA Suspension Setup (suspendedHatch)
you nailed that right on the head. they are pure crap, that is why it feels like a boat.
As far as the DA body goes, what sway bars are out there ?
Old Oct 29, 2007 | 09:35 PM
super jdm yo's Avatar
there's a few suspension technics... progress, there's even a write up where you can put type r swap on g2ic and if you do that then you're open to all the sway bars that are available to dc's.
Old Oct 30, 2007 | 04:39 AM
Si2See's Avatar
cool man, i will try to find that write up. i think i can achieve this for right under 1500
Old Oct 30, 2007 | 04:22 PM
CarPhreak's Avatar
The best bang for the buck is Sway Bar and polyurethane bushings,
And I don't mean polyurethane bushings for the sway bars I mean the hole suspension. About $450 for both.
Or you try what I've got. (see below) Not much can keep up with me in the canyons.
And i use it for Autocross too.
Old Oct 31, 2007 | 04:39 AM
Si2See's Avatar
if i am spending all of this money, I will get the polyurethane master kit also. I want this car to handle like it is on rails
Old Oct 31, 2007 | 11:39 AM
lmike6453's Avatar
cheapest and most efficient for "bang for your buck" would be front and rear strut bars, and rear lower tie bar....after i put in the tie bar, turns weren't a problem in any weather
Old Oct 31, 2007 | 12:26 PM
Si2See's Avatar
thanks for the input, bang for the buck isnt really what i am looking for. I am looking for BEST available setup for the price range i listed
Old Oct 31, 2007 | 03:19 PM
CarFreek's Avatar
If $1500 is your price cap, "bang for your buck" is what your looking for.
What kinda tires are you running?
Tires make a bigger difference than anything else you can put on your car.
Old Nov 1, 2007 | 04:38 AM
Si2See's Avatar
falken azenis are already on the car
Old Nov 1, 2007 | 03:49 PM
CarPhreak's Avatar
Try a set of Bridgestone Potenza RE-01R
If they make them in your size.
QUOTE
Tire Rack:
For the first time in our test history,
the Potenza RE-01R allowed a driver to exceed 1g
(1.003g) on both of his laps on the dry skidpad with our stock BMW 325i.
http://www.tirerack.com/tires/...ocQty=
Modified by CarPhreak at 6:44 PM 11/1/2007
Old Nov 1, 2007 | 05:58 PM
Si2See's Avatar
my tires are fine thanks for the input
Si2See's Avatar
i am actually searching for which rear sway bar to buy. pros and cons of using one or the other maybe anyone ?
Old Nov 1, 2007 | 06:33 PM
CarFreek's Avatar
I have the S/T (F&R), I think they are 25mm(F) and 19mm(R).
The car just about never under-steers, and is only *** happy when i want it to be.
Bigger in the back will make it more *** happy, their is no wrong or rite.
just find a size that will get it to do what you want it to.
(*** happy = over-steer)
If you want to go really big in the back you can use a DC ITR bar.
See post:
"23mm ITR sway bar on a 90-93 Integra"
https://honda-tech.com/zerothread/755865
Old Nov 1, 2007 | 06:37 PM
Si2See's Avatar
car freak check your pm's
Old Nov 1, 2007 | 06:45 PM
CarPhreak's Avatar
it wont let me do that im still set as a trial member.
if you have AIM the MSM messenger or the yahoo messenger i can sign on th one of them.
P.S. Im at work it may take me a little bit to get back to you.
aemintgsr
30
Oct 27, 2012 11:05 PM
datdude814
Honda Civic (2001 - 2005)
Jun 20, 2008 08:36 PM
KillaB-
Jul 12, 2004 07:38 AM
GruvyTune
Aug 14, 2002 08:51 PM
Adampops
Jun 17, 2002 02:33 PM
