Rear bumper is misaligned.
Old Oct 29, 2007 | 01:18 PM
EvenStar's Avatar
Default Rear bumper is misaligned.
1995 Honda accord lx 2dr
How can I remove the rear bumpers? I never knew the rear bumper was a bit loose until I had my sub system installed. There are lots of scratches from the rear bumper (and front) according to the previous owner, and she admits it was caused by parking too close many times. I never noticed it was loose when I bought it.
But when I had my subs in, I thought the trunk was rattling. So I put some dynamat on the trunk and a thick piece of old clothing behind my license plate. It quieted it down a bit, but the loud rattling was there. So I touched the rear bumper a bit and the rattling stop. I let go of it, rattling came back. Repeat. I held the bumper and pushed it up and I can see that its suppose to be connected completely.
Should I just unscrew the rear bumpers and screw it back in if that helps? How do I remove the rear bumper?
Or would it be better if I had the shop work on it? (though it'd be costly for sure)
Old Oct 30, 2007 | 12:32 AM
Twixle's Avatar
ate my pixel
Default Re: Rear bumper is misaligned. (EvenStar)
How to remove your rear bumper: (Note: some of these may be broken on your bumper since it's misaligned.)
Remove the four clips retaining the forward ends of the bumper to the fender well. Remove the plastic screws retaining the bumper cover to the body, remove the side marker lights. From under the vehicle remove two lower bumper retaining nuts. From inside the trunk, detach the trim panels and remove the upper remaining nuts. Slide the bumper to the rear and pull it off.
cybersec
Jul 6, 2017 06:22 AM
rick_rabies
16
Nov 27, 2010 03:50 AM
PowerLeg
Nov 1, 2010 10:05 PM
omehegan
Oct 27, 2004 02:07 PM
Tommy_Gunns
Aug 10, 2002 09:23 PM
