96 spec jdm 4-2-1
Old Jun 21, 2002 | 10:53 PM
R3dL1n3's Avatar
Default 96 spec jdm 4-2-1
Do any of u guys know the collector size of this header? cos sum1 has one for sale bu he says its 2.5" outer dimater but only around 2.25" inned dimater. is this correct?
and what is the collector size of the aussie and US headers?
2" right(inner diameter)?
Old Jun 21, 2002 | 10:58 PM
t's Avatar
t
Default Re: 96 spec jdm 4-2-1 (zxcv123)
correct
Old Jun 21, 2002 | 11:02 PM
uNF$@#!'s Avatar
Default Re: 96 spec jdm 4-2-1 (t)
odd, i thought the usdm had a 2.25" bottleneck as well?
Old Jun 22, 2002 | 02:41 AM
GZR4DR's Avatar
Default Re: 96 spec jdm 4-2-1 (00-0187)
USDM is 2.25 i believe. Might be smaller. The JDM 4-2-1 is noticeably larger than the U.S. version of the header.
Old Jun 22, 2002 | 03:34 AM
DutchITR1689's Avatar
Default Re: 96 spec jdm 4-2-1 (GZR4DR)
The USDM and EuroDM/AUSDM header has a 2" (50 mm) OD flange.
All JDM headers incl. the '96 4-2-1 have 65 mm (2.56") OD flange. The OEM ones have a inner tube which 60 mm OD.
Only the B-pipe is 2.25" (57mm) OD except for the bottlenecks.
Old Jun 22, 2002 | 08:57 PM
R3dL1n3's Avatar
Default Re: 96 spec jdm 4-2-1 (DutchITR1689)
Ok thanks for ur help.
SO what r the differences between a ausdm euro and us header the primary sizes??
Old Jun 24, 2002 | 12:27 AM
USDM = cast iron (OD= ?). Euro/AusDM = not cast iron but only 40 mm OD
Mugen112
Jul 23, 2005 01:29 PM
kalenz
Feb 19, 2005 05:37 PM
acintegragsr
Oct 25, 2004 04:23 PM
fastest
May 7, 2004 10:23 PM
n1racer
Aug 3, 2001 05:05 AM
