89 CRX DX with 90 CRX SI rear sway bar help
Ok well here is my problem. I was going to use my rear sway bar from my 90 crx si parts car on my 89 dx but after I got everything pulled off the si and tried to bolt up the mounting bracket to the frame it's as though there is no nut on the back side of the frame? It has the hole to bolt the bracket too be nothing to thread into. Whats going on?
I have all the mounting hardware off my si and the dx even has the hole in the frame to bolt into but nothing to thread into.
u have to weld thesway bar bracket to a piece of metal then bolt that where the tow hooks bolt. theres a write up with good pics in the FAQ2.o section. lok for it.
That write up was for a DA sway bar but I guess I could extend the mounting bracket to the tow hook bolts if I can figure anything else out. Thanks, anyone else got some suggestions?
VeilSide_Mas
Aug 19, 2006 03:39 PM
CRexcellence
Dec 2, 2003 05:14 PM
squeaky
12
Oct 3, 2002 07:17 PM
