PIC Request: 98+ with front bumper removed
Old Oct 29, 2007 | 10:03 AM
nuckingfuts's Avatar
Default PIC Request: 98+ with front bumper removed
I need to see where the brackets (that help hold the turn signals) go and how they look for a 1998+. I have a 95 db7 and did a 98+ front end conversion and i need to figure out how to retain the brackets (as just the screws isn't enough to hold the light in place securely). I checked the acura website to look at the diagram but the picture is really small
Thanks for any help
Old Oct 29, 2007 | 10:05 AM
nate_2k5's Avatar
Default Re: PIC Request: 98+ with front bumper removed (nuckingfuts)
the brackets are on the bumper itself
numbers 13 and 14
Old Oct 29, 2007 | 10:16 AM
Default Re: PIC Request: 98+ with front bumper removed (nate_2k5)
That is a bigger pic which helps however that is clearly a 94-97 model check the headlight shape and the bumper lights. Are they the same? maybe its because i have an aftermarket bumper cover. I cant see where the brackets are supposed to go. i can snap a few pics
Old Oct 29, 2007 | 11:12 AM
A L I A S's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nuckingfuts &raquo;</TD></TR><TR><TD CLASS="quote">That is a bigger pic which helps however that is clearly a 94-97 model check the headlight shape and the bumper lights. Are they the same? maybe its because i have an aftermarket bumper cover. I cant see where the brackets are supposed to go. i can snap a few pics </TD></TR></TABLE>
no thats a 98+, this is the epc pic for the 94-7
and the brackets just bolt to the bumper...
Old Oct 29, 2007 | 11:35 AM
Default Re: PIC Request: 98+ with front bumper removed (A L I A S)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by A L I A S &raquo;</TD></TR><TR><TD CLASS="quote">
and the brackets just bolt to the bumper...</TD></TR></TABLE>
I'm sorry but you are wrong. While the exploded diagram that I posted was of 1998+, the diagram that nate_25k posted is of 94-97. Again look at the bumper lights and the shape of the headlight. That bumper light turns down towards the end unlike the 98+ which do not.
They are two different part numbers, but I really need to see a pic of the 98+ bracket. That diagram while i'm sure they listed as 98+ is obviously for 94-97. I have had these things apart enough times to notice the differences in model years. Regardless, I appreciate the help
Modified by nuckingfuts at 9:14 PM 10/29/2007
Old Oct 29, 2007 | 12:00 PM
nate_2k5's Avatar
yes it looks to be a 94-97 headlight bu thats the diagram that came up when i searched 98 integra, so i am assuming the brackets are the same
Old Oct 29, 2007 | 08:25 PM
vietnamezerice's Avatar
FTNW
Dec 18, 2010 11:31 PM
00ekcoupe
Jun 29, 2005 01:02 PM
darrinbrewer
Feb 29, 2004 09:45 PM
