Rotten Egg Smell??
Old Oct 29, 2007 | 09:12 AM
Gronked's Avatar
Default Rotten Egg Smell??
I've a 2002 Accord V6 w/ 90k. Every once in a while I smell "rotten eggs". any clues as to where it is coming from?? Also, my spedo is erratic. works fine most days, and then it will die for a couple of miles, then start working again.. Again,, any clues?? Tks in Advance..
Old Oct 29, 2007 | 10:31 AM
raceACCORDingly's Avatar
catalytic converter is usually the culprit for rotten eggs smell
Old Oct 29, 2007 | 11:25 AM
GhostAccord's Avatar
Default Re: (raceACCORDingly)
lol Rotten Egg Smell
A sulfur (Rotten Egg) odor from your car's tailpipe does not necessarily indicate that there is an issue with your cat or the running condition of your car, but is most likely directly related to your fuel. Have you recently changed over to winter gas or changed gas manufacture/station? If it is your cat your ECU/02 sensor should throw a CEL, no CEL probably high sulfer content in your gas. If your CEL light is ON, check for the codes. If you do not have any CEL codes try a different source of fuel.
Old Oct 29, 2007 | 02:46 PM
CD5 Jeebies!'s Avatar
From: Free bullets if you find me sucka, Washington
Default Re: Rotten Egg Smell?? (Gronked)
also your speedo acting erratically is a sing of you VSS vehicval speed sensor taking a ****
Old Oct 29, 2007 | 06:12 PM
YeuEmMaiMai's Avatar
cat converter.....usually happens in colder weather caused by excessive sulfer in the gas
Stevenpc3
Honda Civic (2001 - 2005)
Apr 25, 2011 06:44 PM
Sir Ash
19
Sep 7, 2009 04:42 PM
D16Z6_turbo
14
Aug 27, 2007 06:42 PM
hondaless
Mar 8, 2005 08:08 AM
