I'm Broke Sale: CHEAP, EF , OEM, TURBO, 3 Bar, SOHC, TIAL, ECU, SWAY BAR, DIZZY
Alright, so everything needs to go, I'm seriously flat broke. I no longer need any of it, and am willing to part with it for cheap. Make a fair offer and its yours!
Theres a bunch of stuff so i just took pictures of it grouped together. If you want to see some more pics of anything specific, just let me know. Everything is in great condition except when noted, and if not i will let you know before you purchase.
Here's the list.
- p2m ecu
- pm6 ecu (2)
- pm5 ecu
- zc MPFI intake manifold
- 4 dpfi intake manifolds
- MPFI engine harness, cut, but all plugs are intact
- 3 d15b2's, one rebuilt head, one junk engine, one runs
- dx cable tranny
- resistor box
- ef throttle cable
- 89 crx gauge cluster (everything works)
- ef hatch passenger side fender liner (brand new)
- ef washer bottles w/ motors (2)
- D-series OBDI non-vtec dizzy
- D-series OBDO non-vtec dizzy (2)
- D-series alternator
- D-series ef power steering pumps w/mounts (2)
- stock ef struts and springs
- stock dx intake arms & boxes (2)
- ef si intake arm
- ef radiators (2)
- amp
- d16y8 timing belt (used,but new)
- Tial Wg 35mm (needs new Valve seat, comes with ~7.5 psi spring)
- Tial 35/38mm large blue spring
- stock civic injectors
- T-bolt clamps
- almu/steel piping
- GM 3 bar Map sensor w/ plugs (BRAND NEW)
- d16a6/zc cometic HG, standard bore (brand new)
- ef ST rear sway bar (SOLD)
- 4 14" steelies
- 4 13" steelies
I may have forgotten some things, if you see something in the pics, ask about it and we'll make a deal.
i also have a bunch of high-end paintball gear if anyone is interested.
Modified by 90sedan at 9:17 PM 10/30/2007
Here's the list.
- p2m ecu
- pm6 ecu (2)
- pm5 ecu
- dx cable tranny
- resistor box
- ef throttle cable
- ef si intake arm
- ef radiators (2)
- amp
- T-bolt clamps
- almu/steel piping
- 4 14" steelies
- 4 13" steelies
Do the rear sway bars fit DAs? How much for the 14'' steelies and are they OEM Honda? 206-940-8173 or jdmda7@hotmail.com
90sedan
Jun 15, 2008 07:42 PM
