I'm Broke Sale: CHEAP, EF , OEM, TURBO, 3 Bar, SOHC, TIAL, ECU, SWAY BAR, DIZZY
Alright, so everything needs to go, I'm seriously flat broke. I no longer need any of it, and am willing to part with it for cheap. Make a fair offer and its yours!
Theres a bunch of stuff so i just took pictures of it grouped together. If you want to see some more pics of anything specific, just let me know. Everything is in great condition except when noted, and if not i will let you know before you purchase.
Here's the list.
- p2m ecu
- pm6 ecu (2)
- pm5 ecu
- zc MPFI intake manifold sold
- 4 dpfi intake manifolds
- MPFI engine harness, cut, but all plugs are intact
- dx cable tranny out of a 90
- resistor box
- ef throttle cable
- 89 crx gauge cluster (everything works) (Sold)
- ef hatch passenger side fender liner (brand new)
- ef washer bottles w/ motors (2)
- D-series OBDI non-vtec dizzy
- D-series OBDO non-vtec dizzy (1)
- D-series alternator
- D-series ef power steering pumps w/mounts (2)
- stock ef struts and springs
- stock dx intake arms & boxes (2)
- ef si intake arm
- ef radiators (1)
- amp (sold)
- d16y8 timing belt (used,but new)
- Tial Wg 35mm (needs new Valve seat, comes with ~7.5 psi spring) (sold)
- Tial 35/38mm small blue spring .6 bar
- stock civic injectors
- T-bolt clamps
- almu/steel piping (sold)
- GM 3 bar Map sensor w/ plugs (BRAND NEW) (sold)
- d16a6/zc cometic HG, standard bore (brand new)
- ef ST rear sway bar (SOLD)
- 4 14" steelies
- 4 13" steelies
I may have forgotten some things, if you see something in the pics, ask about it and we'll make a deal.
i also have a bunch of high-end paintball gear if anyone is interested.
Modified by 90sedan at 9:50 AM 10/29/2007
Modified by 90sedan at 9:16 PM 10/30/2007
Modified by 90sedan at 7:38 PM 11/26/2007
Modified by 90sedan at 7:40 PM 11/26/2007
Modified by 90sedan at 7:05 PM 12/19/2007
Modified by 90sedan at 9:54 AM 3/7/2008
Here's the list.
- p2m ecu
- pm6 ecu (2)
- pm5 ecu
- resistor box
- ef throttle cable
- ef si intake arm
- ef radiators (1)
- amp (sold)
- T-bolt clamps
- 4 14" steelies
- 4 13" steelies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series »</TD></TR><TR><TD CLASS="quote">What year is the dx trans ?</TD></TR></TABLE>
90. Opps i should have clarified that.
Bump.
Bump.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dr. D-Series »</TD></TR><TR><TD CLASS="quote">Sweet. Willing to ship to 10461 ?</TD></TR></TABLE>
Sent you a pm!
Sent you a pm!
