CHECK ENGINE LIGHT
that means obviously there is a problem in the vtec solenoid circuit,not intendeing to be smartass.either the solenoid is bad(not likely)or you could have a short in the wiring somewhere,hell the ground could be disconnected.i would check the pins at the solenoid connector first then check the pin at the ecu.
smurfylee
Sep 18, 2008 02:23 PM
GuCCi_GSR
Sep 6, 2008 03:32 PM
