Honda 16" wheels cross match to other vehicles.
Old Oct 28, 2007 | 09:24 PM
2004acuratl's Avatar
Default Honda 16" wheels cross match to other vehicles.
I want to use 16" Honda steel wheels from a 2006 accord on my 2004 Acura TL changing the tire size to get the same roll distance. Need a seperate set of snows for the winter season. My question is: Will the 16" Honda OEM steels bolt up to the 2004 Acura TL?
Old Oct 29, 2007 | 03:54 AM
TouringAccord's Avatar
H-T Order of Merit
Default Re: Honda 16" wheels cross match to other vehicles. (2004acuratl)
I don't know the lug pattern on the TL but the lug pattern on the 2006 Accord would be 5x114.3 so as long as those match you should be fine. Don't forget to double check the offset and width just to be sure though.
Old Oct 31, 2007 | 06:24 PM
Default Re: Honda 16" wheels cross match to other vehicles. (TouringAccord)
Thanks for responding. I know that it is the same as the accord 5 x 114.3. But what is the offset. I thought my only concern would be if the steel wheel allows the caliper to clear it.
Old Oct 31, 2007 | 07:42 PM
hayabusa160's Avatar
steelies are usually 50-55 offset on accords most cases.
but im not sure on the 16inch steelies they should be the same tho.
diversegsr
May 4, 2010 01:14 PM
RICE POLICE SIP
Sep 4, 2006 10:51 AM
KseriesSLUG
Dec 31, 2005 08:51 AM
steves1200
Jul 24, 2005 11:03 PM
