Just rebuilt front calipers, bled brakes, do i need to bleed the rear brakes too?
Old Oct 28, 2007 | 05:13 PM
budomove's Avatar
Default Just rebuilt front calipers, bled brakes, do i need to bleed the rear brakes too?
I just finished rebuilding my front calipers, and did a total flush on the brake fluid. The brakes seem great, but should I also bleed the back brakes?
Thanks Guys!
Old Oct 29, 2007 | 01:15 AM
Tyson's Avatar
Default Re: Just rebuilt front calipers, bled brakes, do i need to bleed the rear brakes too? (budomove)
sure. the old fluid is still in the lines. why not do some preventative maintenance and flush that out as well. you dont want to mix old and new fluid anyway.
Old Oct 29, 2007 | 11:25 AM
HandleTech's Avatar
Default Re: Just rebuilt front calipers, bled brakes, do i need to bleed the rear brakes too? (Tyson)
Whenever you bleed brakes,
a good rule of thumb is to always
start w/the wheel FURTHEST from the Master.
Dont get lazy and just bleed two.
Furthest from the master would be the right rear,
followed by the left rear, then the front right, and last the
front left (unless your right hand drive)
This will push all the bubbles out (if bled properly),
and old brake fluid as Tyson suggested.
Good Luck
Old Oct 29, 2007 | 11:31 AM
loudandlow's Avatar
Default Re: Just rebuilt front calipers, bled brakes, do i need to bleed the rear brakes too? (FuknHeeHAw)
If you look online or in a service manual, you can get the exact specs on which wheels to do when.
Old Oct 29, 2007 | 11:39 AM
ComeOnKip's Avatar
From: Where the wild things are in, NY, United States of America
or you could just tell him.... LHD cars are 99% of the time going to be 1)rear passenger side 2)rear driver side 3) front passenger side 4) front driver side. always start bleeding at the corner furthest from the BMC.
Old Oct 29, 2007 | 12:47 PM
budomove's Avatar
Default Re: (ComeOnKip)
Thanks Everyone, I put it up on jackstands to rebleed the right way, and realized the rear drum bleed screws are frozen, and one is totally stripped.
I was at my parents without my tools, and went at them with cheap open ended wrenches, and just stripped them.
Old Oct 29, 2007 | 01:22 PM
Tyson's Avatar
the rule of thumb is to START at the furthest wheel from the MC. but not necessarily to continue in that order. since the proportioning valve has the DIAGONAL corners in pairs, in case 1 corner should fail, the whole axle's brakes dont fail. this is common for a very long time now. so then you bleed the corners in PAIRS.
so then the order should be
1. right rear
2. left front
3. left rear
4. right front
but really, i dont think it matters in the end once you bleed all the brakes.
Old Oct 29, 2007 | 01:23 PM
Tyson's Avatar
Default Re: (budomove)
well you just learned to use the right tool.
just by a 6pt closed end wrench or socket and itll probably come off even with the rounded corners. best to replace them for the future tho.
Old Oct 29, 2007 | 03:21 PM
budomove's Avatar
Default Re: (Tyson)
Yes, I definitely plan on having the local dealership order in a couple replacement screws, and I hope to get them off with my 6 point socket. I am going to cross my fingers and hope it works. If not, this might be an excuse to switch to aluminum drums that are not rusted apart like mine will be soon. Thnaks for alll the advice!
93CamaroLT1
Nov 15, 2008 01:27 AM
Loserkidwac
Jul 31, 2006 07:46 AM
drew2
Feb 12, 2006 01:19 PM
Leb_CRX
Apr 18, 2002 11:17 PM
