I NEED SOLID INFORMATION ABOUT MOUNTS
Old Oct 28, 2007 | 04:00 PM
clackattack's Avatar
Default PLEASE HELP WITH MOTOR MOUNTS
I have a 97 EX COUPE. I have a JDM B18C on the way, and I also have a set of hasports coming (EKSTK).
I have read, searched, read, and searched some more.
To keep my A/C, I need an A/C bracket from a del sol, which I have found online...correct?
What about some other brackets that I need?
I want this done right and complete.
Also, as far as wiring goes, all I need to do is splice a few of wires near the ecu right?
Modified by clackattack at 5:13 PM 10/28/2007
Old Oct 28, 2007 | 04:57 PM
Default Re: PLEASE HELP WITH MOTOR MOUNTS (clackattack)
the swap has an a/c compressor on it...what do I do about that?
Old Oct 28, 2007 | 05:16 PM
ekb16's Avatar
u will also need the timing belt side motor mount bracket that bolts to the block with 2 studs stickin up from the 99-00 SI and the Rear L bracket from the 99-00 SI
Old Oct 28, 2007 | 06:40 PM
ltrkstr2k's Avatar
Default Re: (ekb16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ekb16 &raquo;</TD></TR><TR><TD CLASS="quote">u will also need the timing belt side motor mount bracket that bolts to the block with 2 studs stickin up from the 99-00 SI and the Rear L bracket from the 99-00 SI</TD></TR></TABLE>
i got both of mine from the honda dealer around here. if you buy it from the dealer the mount that has the 2 studs on it you gotta buy the studs and nuts seperate. The ecu deal depends on what ecu your gonna run. If you switch to obd1 you gotta spice in the injectors,altenator and dizzy. The inj and the alt. are both color matching but the dizzy isn't. Just search on here and you'll find what wires go to what. Just a little help for ya.
Old Oct 28, 2007 | 06:54 PM
97Ej6mike's Avatar
B-swaps into all 96-00 civics can use a large amount of 99-00 civic SI (em1) parts.
Old Oct 28, 2007 | 07:07 PM
Default Re: (97Ej6mike)
what about the a/c?
i need those two brackets out of the si, ON TOP of the hasport kit (EKSTK)?
can you possibly point me to a link, so I don't purchase the wrong ones?
this is what i have
Modified by clackattack at 8:29 PM 10/28/2007
Old Oct 28, 2007 | 07:32 PM
ltrkstr2k's Avatar
Default Re: (clackattack)
I can't really tell you about the A/C deal because im not running it or power steering. But i know there is a link on here somewhere i just don't have the time to look right now. check out the FAQ's on the top of the threads
Old Oct 28, 2007 | 07:58 PM
VegasHB's Avatar
Default Re: (ltrkstr2k)
SI Engine Mount Bracket Timing Belt Side - 11910-P30-000 - $52
Engine Mount Bracket Bolts - 90041-P01-000 - $5.40 x 2
Parts 22 & 8 in pic
http://www.slhondaparts.com/br...=true
SI AC Bracket/Mount - 38930-P30-000 - $120
Part # 1 in pic
The L bracket I'm not sure about, might be #7 in the pic above I think.
Old Oct 29, 2007 | 01:58 AM
Default Re: (VegasHB)
with the 99-00 a/c bracket as shown....
do I use the compressor that comes wiht my swap (b series) or do I use my stock d-series compressor?
Old Nov 1, 2007 | 06:43 PM
ekb16's Avatar
i think u can use the d series compressor
Old Nov 1, 2007 | 09:27 PM
Default Re: (ekb16)
i dont see why I cant just use the a/c compressor thats already on my block (b18c)
B20typeR
10
May 6, 2009 09:55 AM
yayizzil
Apr 3, 2009 01:05 PM
blackeg
May 2, 2005 07:50 AM
lga860
Sep 13, 2004 12:34 PM
Ej6B20
Apr 9, 2004 04:39 AM
