rpm issue
Old Oct 28, 2007 | 01:38 PM
player01018's Avatar
Default rpm issue
My rpm gauge when i turn car on for a few minutes it goes from 1-2 and back and forth for a bit. I think it is probeally my radiator since it has a crack on the top of it. Any ideas?
Old Oct 28, 2007 | 04:12 PM
97Ej6mike's Avatar
Default Re: rpm issue (player01018)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by player01018 &raquo;</TD></TR><TR><TD CLASS="quote">My rpm gauge when i turn car on for a few minutes it goes from 1-2 and back and forth for a bit. I think it is probeally my radiator since it has a crack on the top of it. Any ideas?</TD></TR></TABLE>
A fluctuating idle has to do with the IACv (Idle air control valve) and FITv (fast idle themro valve) parts. a cracked radiator wouldnt necessarily cause it to do that.
Edit: Actually, IACv uses coolant temp, so if it were getting an inconsistent flow (too much air mixxed with coolant) It would cause it to malfunction
Modified by 97Ej6mike at 7:30 PM 10/28/2007
Old Oct 28, 2007 | 04:58 PM
Default Re: rpm issue (97Ej6mike)
i noticed if i fill it up full it is fine but it if it does it it is empty.
Old Oct 28, 2007 | 05:18 PM
Formula's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by player01018 &raquo;</TD></TR><TR><TD CLASS="quote">i noticed if i fill it up full it is fine but it if it does it it is empty.</TD></TR></TABLE>
You may be getting air in the coolant system because your radiator has a leak.
Get a new radiator and see if it fixes the problem. The way it sounds you need a new radiator anyway.
Old Oct 28, 2007 | 06:32 PM
islandauto's Avatar
I would buy a new radiator and bleed the system properly and see what happens
Mikes95eg
Apr 1, 2013 08:36 AM
Tony.V
14
Nov 4, 2009 12:43 AM
Bull_head360
Oct 12, 2004 07:33 PM
cool
Dec 31, 2003 07:26 PM
Ri5e
Mar 30, 2002 03:57 PM
