disc brake swap
there is a 91 crx si in local junkyard that i plan on getting trailing arms from. i know i have to remove the e brake lines for the swap. My only question is will the brake lines from my 88 crx fit up to the calipers on the 91 si brakes?
I don't believe so, and my reason behind this is when you buy brake lines for a CRX the part # is diff for the SI because it has back disc brakes. So get the lines when you pull everything. To bad your not close to me I am selling some or $80.00. Both sides with rotors.
and how would i go about getting the e brake lines out of there? i know how to disconnect them from the inside and from the caliper but which end do i pull em out from?
https://honda-tech.com/zerothread/1508680
http://crf50.no-ip.com/fourthg....html
You need what ever brake lines were with the disc brakes so either need CRX Si 90-91 lines or 90-93 Integra lines. There is also a metal clip that holds the rubber line to a solid mounting point on the car, pop that clip and the rubber line will be free.
GeoMetry
Nov 11, 2015 09:20 AM
