car is not pullling hard? starter problem?
How u guys doing? FIRST PROBLEM>anyway im having problem wit my 95 ls 2dr, for some reasons im having a hardtime changing gears from 1 to 5.. i checked my clutch and it seems fine to me.. some people say i need to get the clutch wire to be bleed..wat should i do? how can i fix it guys? Oh, and doesnt go as fast as it used to
SECOND PROBLEM>when u start the ignition, the car doesnt start up right away.. you can only hear a click at 1st try then 3 try then thats when the car starts... do u guys think its the starter? or something else? thank you guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dc2 frm da island »</TD></TR><TR><TD CLASS="quote">How u guys doing? FIRST PROBLEM>anyway im having problem wit my 95 ls 2dr, for some reasons im having a hardtime changing gears from 1 to 5.. i checked my clutch and it seems fine to me.. some people say i need to get the clutch wire to be bleed..wat should i do? how can i fix it guys? Oh, and doesnt go as fast as it used to
Your shifting issue could be anything from loose shiftlinkage to tranny fluid, clutch master/slave cylinders being faulty etc...
</TD></TR></TABLE>Your shifting issue could be anything from loose shiftlinkage to tranny fluid, clutch master/slave cylinders being faulty etc...
Yeah, its probably the starter. Try tapping it with a hammer and see if it works better.
</TD></TR></TABLE>Yeah, its probably the starter. Try tapping it with a hammer and see if it works better.
ch0baca
12
Nov 18, 2009 09:21 AM
