recommended fuel
Old Oct 28, 2007 | 07:54 AM
blackcherry's Avatar
Default recommended fuel
I just recently picked up a 2000 integra GSR and unfortunately it didnt come with an owners manual so i was wondering what type a fuel is supposed to be run through it? Tried searching but nothing came up for a stock gsr
Old Oct 28, 2007 | 07:58 AM
nate_2k5's Avatar
Default Re: recommended fuel (blackcherry)
91 at least
Old Oct 28, 2007 | 08:49 AM
stuie08's Avatar
if you look at your gas door, it says premium fuel only.
therefor, i only and everyone that has a gsr should use premium or the higher octane gas
Old Oct 28, 2007 | 09:04 AM
goheel's Avatar
Default Re: (stuie08)
yep, premium only. It's not worth it to go cheap.
Old Oct 28, 2007 | 09:28 AM
DOHCgarage919's Avatar
From: Why To Steal My Car, NC, United States Of America
Default Re: (goheel)
here in nc we have 93 so thats what i fuel up on 93
Old Oct 29, 2007 | 10:16 AM
i filled up today with 93 (we only have 87/89/93) today just to be safe but i guess thats what is required anyway. i wasnt sure if acura said 87/89 is normal but i guess not. thanks
Old Oct 29, 2007 | 10:17 AM
btw does the higher octane gas have anything to do with it being vtec? or is that just what they want you to use?
Old Oct 29, 2007 | 10:30 AM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: (blackcherry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcherry &raquo;</TD></TR><TR><TD CLASS="quote">btw does the higher octane gas have anything to do with it being vtec? or is that just what they want you to use?</TD></TR></TABLE>
higher octane gas really is 87 octane with a concentrated amount of vtec fluid added in...this benefit only is brought out when driving a honda equipped with valve timing and lift electronic control
Old Oct 29, 2007 | 10:31 AM
AWD Terror's Avatar
Umm... seeing how that's the main difference, I would have to say yes.
Old Oct 29, 2007 | 10:55 AM
Dogginator's Avatar
Daisy... Daisy...
The compression ratio and the tuning dictate that premium fuel is needed. Your GSR will run on lower octane, but will have less power. In stock form, the knock sensor provides feedback to the ECU to protect the engine.
Old Oct 29, 2007 | 12:43 PM
clayfight3r's Avatar
I've got an 01 and it says to use premium on the gauge cluster. Didn't realize it until after i filled for the first time with mid-grade after buying it. But yeah, premium.
Old Oct 29, 2007 | 12:51 PM
dizzzane's Avatar
Default Re: recommended fuel (clayfight3r)
As dogginator stated, the higher CR of the GSR motor (10.6) is what requires the higher octane gas. It won't harm the engine to run 87 but you won't be maximizing the GSR engines efficiency. You will actually get better gas mileage in your GSR with 93.
Old Oct 29, 2007 | 02:20 PM
Jackson123's Avatar
Default Re: recommended fuel (dizzzane)
i have a 94 ls, premium too?
GRAF-FITI's Avatar
* B A N N E D *
Default Re: recommended fuel (Jackson123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jackson123 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 94 ls, premium too?</TD></TR></TABLE>
not necessary
Old Oct 29, 2007 | 02:28 PM
all-mtr-teg's Avatar
USDM GSR is 10:1, JDM GSR is 10.6:1
Old Oct 29, 2007 | 04:59 PM
MeanGreenMachine's Avatar
Default Re: recommended fuel (all-mtr-teg)
91 octane for gsr motor
Old Oct 30, 2007 | 05:49 PM
NeoGSR's Avatar
Default Re: recommended fuel (MeanGreenMachine)
hard to find 93 around here....but 91 is just fine.
Old Oct 30, 2007 | 06:03 PM
Default Re: recommended fuel (NeoGSR)
here in NC we only have 87,89,93 so 93 you find everywhere when i lived in cali 91 was the highest they offered
Old Oct 30, 2007 | 06:12 PM
HondamanXxX's Avatar
GO GIANTS!
Default Re: recommended fuel (DOHCgarage919)
91-93
Fg2_herrera805
Honda Civic (2006 - 2015)
31
Apr 26, 2012 07:28 AM
cinder0159
Apr 19, 2011 01:10 AM
jdmjoka
Mar 1, 2009 12:52 AM
JoshuaVTEC
28
Sep 25, 2005 07:13 AM
integraboi1010
Aug 25, 2004 01:28 PM
