DC2R Shocks/LCA Install
I have 95 GSR on OEM shocks and springs.
To do the DC2 ITR shocks and spring and Rear LCA Install - is there anything else I need?
Additional Bolts or anything?
Fronts should be easy, just an easy swap. But with the rears, I'm not sure if I'll need any additional bolts etc.
My rear itr lca, and itr shocks/springs didn't come with bolts.
Thanks
Thanks
That's all you need. You can reuse all the nuts and bolts from your gsr. You are going to have to secure your speed sensor wires to the lca somehow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcRay »</TD></TR><TR><TD CLASS="quote">That's all you need. You can reuse all the nuts and bolts from your gsr. You are going to have to secure your speed sensor wires to the lca somehow.</TD></TR></TABLE>
Isn't this also the case for the ABS lines?
guitarguru87
Feb 4, 2009 07:58 AM
isuhonda83
Sep 22, 2004 05:44 AM
Carp
Apr 3, 2002 01:13 PM
miketegra
Nov 1, 2001 11:28 AM
