which spark plug wires are best for 96 honda civic ex?
Old Oct 27, 2007 | 11:17 PM
ShinotakuX's Avatar
Default which spark plug wires are best for 96 honda civic ex?
also, what is the brand name for the oem spark plug wires? I know the spark plugs are NGK but I'm not sure about the wires, thank you.
Old Oct 27, 2007 | 11:22 PM
Eran's Avatar
HT White Ops
The stock spark plug wires were originally made by Nippondenso (DENSO). They are now made by Prestolite.
The stock sparkplugs are either Nippondenso or NGK (depending on your area/emissions).
As far as buying aftermarkt -- buy NGK V-Power ZFR6F-11. You can get a 4-pack at Schucks/Checker/Kragen for about $8.00. Gap at .044mm and be happy. For wires, buy just the standard NGK wires.
Old Oct 28, 2007 | 08:22 AM
Bazza's Avatar
or you can go buy some good plug wires made by MSD. theyll be your best bet. they work great and you can get em in bigger sizes... but for bigger sizes you should get a new distributor... but for now id go with Eran unless you wanna spend some money which in that case go MSD.
Old Oct 28, 2007 | 08:31 AM
big-cat's Avatar
stock are the best.
Old Oct 28, 2007 | 08:37 AM
suspendedHatch's Avatar
Default Re: (Bazza)
Magnecor is the best and doesn't cost much more than NGK. You never have to replace the wires again. Have been running them daily for 4 years now.
Don't believe the gimmicks.
Old Oct 28, 2007 | 09:44 AM
EK_B's Avatar
I got some Denso ones at Autozone for under $10 about a year ago.
Old Oct 28, 2007 | 09:45 AM
Eran's Avatar
HT White Ops
Default Re: (Bazza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bazza &raquo;</TD></TR><TR><TD CLASS="quote">or you can go buy some good plug wires made by MSD. theyll be your best bet. they work great and you can get em in bigger sizes... but for bigger sizes you should get a new distributor... but for now id go with Eran unless you wanna spend some money which in that case go MSD.</TD></TR></TABLE>
Shut up. Please.
MSD plug wires will not net you any performance gains over stock or standard NGK. You might as well light your money on fire and then **** on it.
Old Oct 28, 2007 | 09:55 AM
SilverStreak02's Avatar
Default Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eran &raquo;</TD></TR><TR><TD CLASS="quote">
Shut up. Please.
MSD plug wires will not net you any performance gains over stock or standard NGK. You might as well light your money on fire and then **** on it.</TD></TR></TABLE>
+1
Out of all the plug wires I've delt with, nothing is better then OEM or NGK.
Old Oct 28, 2007 | 10:07 AM
egjdmcivichatch's Avatar
Default Re: (SilverStreak02)
ngk power cables
the best wires on the market, read up on them
just my opinon
Old Oct 28, 2007 | 10:54 AM
EK9Tune's Avatar
.044m gap is for a d16y7 right?
mawkiemarc
Apr 5, 2005 09:30 AM
nickgmiller04
Mar 13, 2004 12:11 PM
BoBo Racing
Feb 16, 2003 03:29 PM
JDM 007
Sep 17, 2002 02:51 PM
CivicEsEye
16
Jan 1, 2002 08:29 AM
