92 Integra ABS Light Help
Old Oct 27, 2007 | 11:06 PM
tsunami604's Avatar
Default 92 Integra ABS Light Help
I have a 92 integra GS and the ABS light is on. What is most likely the problem? Is there a way i can disable the abs and get the light on the dash to go out by pulling a fuse??
Old Oct 27, 2007 | 11:14 PM
jjzend600rr's Avatar
here you go...
https://honda-tech.com/zerothread?id=978933
OPPS!.not the right one..hold on!..
http://www.team-integra.net/se...D=646
hope this helps..
Modified by jjzend600rr at 12:26 AM 10/28/2007
Old Oct 28, 2007 | 01:00 AM
1DA2NV's Avatar
have you stopped to think why the light is on? mine was the same and all it took was an hour or so to fine the one sensor that was having the problem, clean it make sure it was in place prpoerly and put back together
Old Oct 28, 2007 | 11:04 PM
tsunami604's Avatar
Default Re: 92 Integra ABS Light Help (tsunami604)
^^ what was the sensor that you removed and cleaned up?
Old Oct 29, 2007 | 04:24 AM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tsunami604 &raquo;</TD></TR><TR><TD CLASS="quote">^^ what was the sensor that you removed and cleaned up?</TD></TR></TABLE>
Wheel sensors can become dirty. Pull the codes for an easy diagnosis.
JJtegfan14
Aug 5, 2009 10:27 AM
lsturbo*
May 19, 2008 11:58 PM
obscure detour
May 28, 2005 08:23 PM
NeriVTEC
Feb 25, 2005 02:52 PM
