Retro into my JDM headlights, have a question about wiring ....
Got all the parts, now its time for the install.
My question ... the wiring from the ballast to the power source << I want to run the positive and negative from each ballast into my Factory halogen wiring harness ( pass. and drivers sides ).
Is it as simple as cut the socket off and tap into the wiring or do I need a relay in between?
Any fuses to upgrade ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">I would recommend using a relay setup, and drawing power directly from the battery. </TD></TR></TABLE>
I thought about this, but doesn't the oem harness already run through a fuse and headlight relay ??
bz_kurb
Honda Civic (2001 - 2005)
Aug 29, 2008 06:20 PM
