Alternator and Regulator Amperage problems?
Old Oct 27, 2007 | 08:40 PM
hondastrtracr's Avatar
Default Alternator and Regulator Amperage problems?
I have a 99 civic ex and for a couple of month now when the car is running down the highway or sitting at a stop light all the light kinda fluctuate dim and get brighter over and over again at a constant frequency... Is this due to a bad alternator or regulator, isnt these civics internally regulated with in the alternator? Help!
Old Oct 27, 2007 | 08:48 PM
97Ej6mike's Avatar
Usually those symptoms you explained would indicate a bad alternator.
Old Oct 29, 2007 | 08:30 AM
GoLowDrew's Avatar
Old Member
25 Year Member
Default Re: Alternator and Regulator Amperage problems? (hondastrtracr)
If you have a multimeter (they are cheap) and take two readings.
Take a reading with the engine off. It should be at about 12V.
Take a reading with the engine on (all other electrical off). It should be about 14V.
This will also narrow down the problem if it's with the battery or alternator.
Old Oct 29, 2007 | 12:11 PM
crazyguy's Avatar
yeah and soon or later.the battery light will come on at your cluster...then time for a new alternator..bring it to local parts stores.they will test it for u at no charge
89edcivic
Sep 26, 2009 02:38 PM
88 EF Hatch
Sep 17, 2009 07:29 AM
sixgunsound
Jun 7, 2009 05:45 PM
crx_88_si
16
Jun 2, 2006 04:04 AM
BoostingLS
Oct 7, 2002 07:24 AM
