Identify this green plug on OBD2B harness
Old Oct 27, 2007 | 08:32 PM
hmtcrxsir's Avatar
Default Identify this green plug on OBD2B harness
I found out that Blue Harness Plug is Connector "C" and the Grey Harness plug is Connector "B" according to http://www.ff-squad.com/technet/wiring.obd2b.htm but somehow I cant manage to find Connector "A" ? And what is this green plug connector?
click on link if pix dont work.
http://a912.ac-images.myspacec...7.jpg
http://a149.ac-images.myspacec...c.jpg
Modified by hmtcrxsir at 9:49 PM 10/27/2007
Old Oct 27, 2007 | 08:57 PM
Luserkid's Avatar
Default Re: Identify this green plug on OBD2B harness (hmtcrxsir)
Green plug connects to the dash harness that connects to the dash.
Old Oct 27, 2007 | 08:58 PM
hmtcrxsir's Avatar
Default Re: Identify this green plug on OBD2B harness (Luserkid)
then where is connector "A"? is it suppose to be on the engine harness?
Old Oct 27, 2007 | 09:09 PM
pdiggitydogg's Avatar
'A' shouldnt be too far from the other plugs, unless it was cut off.
Its the same width as the dash connector, but it has the same construction as the blue and dinky grey one you have shown (C and D respectively) - with the white cap so you can remove pins.
Looks like a 96-98 harness, huh?
Old Oct 27, 2007 | 09:12 PM
hmtcrxsir's Avatar
Default Re: (pdiggitydogg)
does that look like a 96-98 Civic EX Engine harness to you? I double check the pins for where the pins is located and it matches.
Old Oct 27, 2007 | 09:16 PM
Luserkid's Avatar
Default Re: (hmtcrxsir)
The missing plug is inside the car. Cant tell if its any harness without looking at the wiring and see whats there and whats not.
Old Oct 27, 2007 | 09:21 PM
hmtcrxsir's Avatar
Default Re: (Luserkid)
So connector "A" should be inside the car? Because I dont see any signs of connector "A" being cut off from the engine harness.
Old Oct 27, 2007 | 09:32 PM
That little grey plug certainly looks like connector D to me... That would be obd2a. If it were obd2B it should be larger than what I see. (then agian, its been a very long day)
I dont think that A should be left off the harness.
I'll go look at my harness...
Can you get a better shot of that area? 'A' should be right there...
Oh, and your dash plug is missing a lot of wires...
Old Oct 27, 2007 | 09:38 PM
hmtcrxsir's Avatar
my dash plug is missing alot of wires? can you check yours and let me know what you find out while i upload these photos.
Old Oct 27, 2007 | 09:41 PM
Did this harness come off a fully working car? Your car or did you buy it off someone?
If Im just not seeing the (D) grey plug right, and its actually B, then discount everything Ive said.
Agh I shouldnt even be on the boards this late...
Old Oct 27, 2007 | 09:52 PM
hmtcrxsir's Avatar
well i bought it from a guy that claims its from a 99-00 Civic Si. But I have no clue because I dont have much experience with OBD2 engines. But after looking thru the diagram on ff-squad. It looks more like the OBD2B rather than the OBD2A engine harness. But heres a better shot of the grey connector (yeah I know I need a new damn camera.)
Old Oct 27, 2007 | 09:55 PM
suicide_shift's Avatar
* B A N N E D *
99-00 si = obd2b
Old Oct 28, 2007 | 11:06 AM
Yep ok it is plug B, thanks for the better pics
Ignore most of what Ive said so far
Old Oct 28, 2007 | 11:25 AM
hmtcrxsir's Avatar
I dont think i can just use the Civic Si engine Harness on my 97 Civic. Plug "A" which is not on the actual Civic Si harness itself is different. I would have to change the cabin floor harness as well
Old Oct 28, 2007 | 11:33 AM
Ohhh... Yeah, no way in hell do you want to use that harness on an obd2a chassis - you will run into dozens of wiring/electrical difficulties.
Resell that harness and get yourself a 96-98 ex harness instead.
It will snap right in and work perfectly.
Old Oct 28, 2007 | 11:38 AM
hmtcrxsir's Avatar
I probably will redo the whole cabin wirings. Hey Thanks for your helps Unless there is another way beside redoing the whole cabin harness
Modified by hmtcrxsir at 12:57 PM 10/28/2007
Old Oct 28, 2007 | 02:06 PM
You would be redoing a LOT
If I were you, I would just get the appropriate harness and sell that one.
Old Oct 29, 2007 | 10:29 AM
hmtcrxsir's Avatar
what if i were to use the OBD2B to OBD2A conversion harness as described in:
https://honda-tech.com/zero...08225
Old Oct 29, 2007 | 04:32 PM
that wouldnt help things like the tach and other dash goodies
the harness does a lot more than just control the ecu
roosie
Mar 7, 2019 10:29 AM
carlos8
Feb 24, 2017 11:28 AM
andrew781
May 27, 2015 08:20 AM
Pancho2193
Nov 24, 2012 10:02 PM
