D15b won't start
Old Oct 27, 2007 | 07:56 PM
blu_ej's Avatar
Default I need help with my rex.
I have a 1990 crx with a jdm d15b and for some reason it wont start anymore. It started before and now it juyst cranks. I have the stock dizzy so there is only one bolt holding it. I know the firing order is 1342 but does it matter where the #1 plug is set on the dizzy? I know that the #1 plug is set right before the rotor contacts but it still does not start even with me turning the dizzy back and forth. Help me get it back on the road.
Old Oct 27, 2007 | 07:57 PM
EFing8's Avatar
could be a fuel related issue. maybe your pump is dead.
Old Oct 27, 2007 | 08:06 PM
loudandlow's Avatar
Default Re: I need help with my rex. (blu_ej)
ok, get the right distributor.
Old Oct 27, 2007 | 08:15 PM
blu_ej's Avatar
Default Re: I need help with my rex. (loudandlow)
nope fuel is working
Old Oct 27, 2007 | 08:17 PM
blu_ej's Avatar
that dizzy had the car running. but i do have a obd1 dizzy that will bolt up right is the motor but i need to rewire it so do u got a wire diagram.
Old Oct 27, 2007 | 09:03 PM
loudandlow's Avatar
the FAQ page does!
Old Oct 27, 2007 | 09:34 PM
crxfreak1117's Avatar
did it just start doin it all of a sudden if so check ur main relay
Old Oct 27, 2007 | 09:52 PM
blu_ej's Avatar
Default Re: I need help with my rex. (crxfreak1117)
main relay is working got fuel and spark. you can hear the main relay click.
Old Oct 27, 2007 | 10:19 PM
have u checked ur timing?
Old Oct 28, 2007 | 03:05 PM
90 Si Hatch's Avatar
First off i did the same swap in my car and i tried rigging the distributer and it didn't work. So get all the right **** and quit with the BS rywire.com can help you out with the plug and play harness. now i have no more worries
Isaac-
smokey68321
18
Feb 5, 2010 01:21 AM
themex77
Feb 16, 2007 08:58 AM
ilovejdmhoes23
Jan 18, 2007 11:30 PM
Dean80Z28
13
May 20, 2004 04:12 PM
.ShawnD.
Aug 31, 2002 02:57 PM
