Rear Disc Swap Need Link
I am going to take the rear drum off my 95 EX coupe and put it on my 95 4door LX and take the disc off the LX and put it on my EX. I was wondering if anyone had a write up on how to do this in case i run in to any problems.
A write up on this would be nice to have....i searched but just came up with FS posts
its really easy, the hardest part i found was the ebrake cables inside the cabin
its just unbolt everything holding the assembly up and swapping it.
i just did a swap from drums to disks using an Ls teggs rearend. Hardest part is the e-brake cables. I only bolted 2 brackets in on each side (***** a pain with the exhaust attached) and zip tied them up and away from the exhaust (and if you do this, remember to remove the other brackets you dont use, youll thank me later). just try and get a friend to help you out with the cables when your puttting them in the cabin. Everything else is straight forward, and bolts right up. having an extra jack around to help mount up the trailing arms is useful as well, or another person.
pm me if you need more help.
