Ignition harness overheating problem
Old Jun 21, 2002 | 06:51 PM
Another B16's Avatar
New User
Default Ignition harness overheating problem
Has anyone had this problem: I had a stock 88 rex and the key switch gets really hot and burns out the switch contacts. The wiring also gets hot. I probably have a short somewhere, but where do I start looking? Thanks
Old Jun 21, 2002 | 07:01 PM
4wsB21a's Avatar
New User
Default Re: Ignition harness overheating problem (Another B16)
check all your ground wires. sounds like one is not connected. there are grounds all along the wiring harness. not a fun thing to look for.
Old Jun 21, 2002 | 07:17 PM
reXem's Avatar
Default Re: Ignition harness overheating problem (crxplus)
I agree....it sounds like ignition is grounding through the key column.....but the grounds should be in the kick panel near the fuse panel....they don't just stick them ***** nilly....
Toomanylemons
Mar 5, 2017 11:27 AM
wutupnut
May 17, 2011 04:11 PM
Ktribb87
Apr 24, 2011 12:48 PM
Marlon88
May 14, 2006 05:29 AM
bosco500
Aug 11, 2005 01:16 AM
