GSR Swap Issues (TPS)
Motor is in, here is a pic of how the TPS sits:
I can't fit the TPS plug because the top heater hose metal thing is in the way. Anyone else ever had this issue? What to do?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crx-b16 »</TD></TR><TR><TD CLASS="quote">lol plug to short to the sensor or the does the wire wall stuff block it? hit me back should just cut and instead the wires should work...</TD></TR></TABLE>
huh?
huh?
take the fuel hose off and cut the braket that attaches it to the firewall. cut it off and reattach and bend it to the side. It bends quite easily by hand. If you dont whan your motor moves it will smash the tps. Eveyone I have seen does this. You should be able to get the wires to get to the tps, just take the wires out of the loom and try to get some more slack.
jwbnavy
Dec 4, 2007 02:20 PM
