heavy vibration and a squeaking noise coming from the front end.
Old Oct 27, 2007 | 11:15 AM
dumkopf's Avatar
Default heavy vibration and a squeaking noise coming from the front end.
I went for a drive in the mountains. On the way down a heavy vibration started coming from the front end. Can't pinpoint exactly where.
Old Oct 27, 2007 | 03:42 PM
ethereal2pt2's Avatar
Default Re: heavy vibration and a squeaking noise coming from the front end. (dumkopf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dumkopf &raquo;</TD></TR><TR><TD CLASS="quote">I went for a drive in the mountains. On the way down a heavy vibration started coming from the front end. Can't pinpoint exactly where.</TD></TR></TABLE>
the engine vibrates, and the front end is usually where the motor is. maybe it's your motor jokes aside, could be your engine mount(s)? might want to check that. happened to me before.
Old Oct 27, 2007 | 04:06 PM
JDMgareth's Avatar
does the vibration make any thudding/clunking?
maybe axel shaft/hub assembly. I had that issue but there was a noticable thudding noise.
Old Oct 28, 2007 | 01:06 AM
dumkopf's Avatar
Default Re: (JDMgareth)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMgareth &raquo;</TD></TR><TR><TD CLASS="quote">does the vibration make any thudding/clunking?
maybe axel shaft/hub assembly. I had that issue but there was a noticable thudding noise.</TD></TR></TABLE>
Yeah, it does make that noise. I really hope it's not terrible though. How much do axles run anyway?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ethereal2pt2 &raquo;</TD></TR><TR><TD CLASS="quote">
the engine vibrates, and the front end is usually where the motor is. maybe it's your motor jokes aside, could be your engine mount(s)? might want to check that. happened to me before.</TD></TR></TABLE>
This guy. What am I checking for exactly?
Old Oct 28, 2007 | 02:05 AM
Default Re: (dumkopf)
maybe to see if they're loose? damaged? or worse, gone.
Old Oct 28, 2007 | 08:32 AM
cb7tougeracer's Avatar
Default Re: (ethereal2pt2)
maybe a front end bushing kit or control arms
lindsaylou
Honda Civic (2001 - 2005)
Jul 22, 2008 06:44 PM
(760)doogie
Apr 27, 2008 01:49 PM
IlladelphSi
Honda S2000
11
Dec 15, 2006 09:41 AM
jdmda9
Nov 30, 2005 03:33 PM
KRiS1
Sep 2, 2003 04:09 PM
