bouncy ride
Hi, I wonder if bouncy ride is the cause of cheap springs or not. I lowered my car about 1.5" front and rear, I have a bouncy ride, even shock because the rear move up so much and down fast. I noticed that my brother's Acura TL-S have a stiff stock suspension but very forgiving on the bumps.
I have a 1996 HOnda Accord LX 4cyl with KYB shocks, ebay lowering springs in front, Aerospeed lowering springs in the back.
Thanks
Thanks
By bouncy what do you consider bouncy? If you hit a bump do you bottom out and bounce right back up or do you bottom out and your suspension goes up and down a few more times? (continuous bounce or rubber ball effect)
If you get the rubber ball effect I would say you probably have a blown strut. gr-2'S + Any 1.5" lowering springs = Possible blown strut. Look for oil or dark fluid down the sides of your struts. If your suspension has been bouncing for a while that could mean that your struts may be totally empty.
Now if your talking hitting a bump and bouncing but not getting the rubber ball effect. That is more than likely a week spring and strut combo.
Modified by GhostAccord at 11:48 PM 10/30/2007
The front has ebay springs better more forgiving than the back, and I think because of the weight difference. The rear usually give me the shock in the seat because it bounces so strong and come back down so fast. I don't have rubby ride, and the struts are GR-2 and are in good condition, I tested them.
I'm thinking softer springs better and more forgiving but still stiff, and eBay springs is meeting my specs. :D
dont want to jack your thread of anything but i have tein basics and mine feel bouncy. its not like they bounce up and down after i hit a dip but when i do hit one, i almost bounce out of my seat into the ceiling. ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 »</TD></TR><TR><TD CLASS="quote">dont want to jack your thread of anything but i have tein basics and mine feel bouncy. its not like they bounce up and down after i hit a dip but when i do hit one, i almost bounce out of my seat into the ceiling. ideas?</TD></TR></TABLE>
Yup, same here and your set up is way better than mine. The only thing I can think of is may be because of the short travel distance(from lowering) so we hit the bump stop early than stock, which causes the car to jump and you inside follow it.
So I guess there's nothing we can do about it, it's the design of my honda suspension system.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gosu08 »</TD></TR><TR><TD CLASS="quote">i do have coilovers. they are tein basic coilovers....</TD></TR></TABLE>
and I know tien isn't cheap
luv2splooge
Dec 22, 2010 11:44 PM
SL!M
Jun 24, 2003 06:08 PM
