Wideband converter (searched)
I have done lots of searching but I have one question. Is there a device that will take a wideband output and convert it to a narrowband output? I plan to run hondata in the future wide the wideband output directly in, but right now I have a stock ecu. A wideband like this:
http://cgi.ebay.com/ebaymotors...sting
only has a wideband 5v output. Is there a conversion module that will allow me to use it with my stock ecu?
I have found this device:
http://www.zeitronix.com/Products/zt2/zt2.htm
that does have a 1v narrowband output, but I like the AEM unit more. I wanted to know if there is a device that will allow me to use it with my regular ecu. Thanks.
check out the JAWS system on http://www.14point7.com
a lot of people seem to like it and i plan on using it myself
i got the zeitronix and run a pm6 in my car.
works fine.
also very reliable, i run it every day daily driving and i have yet to have an issue.
also the zeitronix sensor is only 60$
works fine.
Thanks for the tip on the innovate controller. I have decided to go with that one. Only reason why I chose that over the zeitronix is cause I like the way the innovate gauge looks more.
TwoKSiR
Engine Management and Tuning
Jun 21, 2008 11:05 AM
