BUDDY CLUB CAMSHAFT IN B16A
Hi,i've a stock b16a2 engine and interested to move on a buddy club spec 4 camshafts package.How much power can i expect in addition with a b16b pistons and the buddy club cams,dual valve springs,retainers and adjustable cam gears.With all these aftermarket parts,will i require to do any other mods to fit these parts,like ecu upgrade,fuel delivery,more air,etc..?
I wouldn't use B16B pistons, there are better choices. Use the search to help make a decision. And you should always get your car tuned if you change hard parts like cams or increase your compression.
But you say so,is there anything wrong with the cams,I'm not only going to put the cams.Obviously,i'll put the titanium retainers,dual valve springs,ecu upgrade and even if i need to change my I/M,it'll be done in a professional manner.Adjustable cam gears are not ignored,injectors,ctr pistons.That would be a great power.
the spec 3s would be better for you as they are not so aggresive.. and have a decent idle..
the stage 4 are for all out built race engines or ppl making serious power,
Just my 2 cents..
Just my 2 cents..
i'm getting a package.I understand,it might be too aggressive,they open at 306 and close at 302.But can we make adjustment of the cams,not open it too much?By the cam gears?
Spoon_monkey
Jun 1, 2005 05:43 PM
