Car Bogging (searched)
yes i already did my research and i think it could be the fuel filter, spark plugs, timing belt missing a teeth, vaccum leaks or fuel injectors need cleaning, i check the code and it was 72 random misfire cylinder 2, Car btw is 1998 integra ls , 149 xxx, mods- short ram intake. car bogs with medium pressure around 1k- 2900 rpm and after that it runs fine, sounds like a boat with alot of rattling. What do you think the problem is ? thanks in advance
This is a stretch but it's happened to me...make sure your distributer isn't losing power. I had my air filter rub up against it and it took voltage out of my dizzy, which caused a bog.
lol, ok so i just use the seafoam today, new boshe platinum spark plugs, oil change, and it still does it, i read the CEL code again today and it was 71 72 73 74, all 4 random misfire cylinder!!? whats my problem???
i have a 96 dc2 and it does the same thing but sometimes i cant put it in first and wen i take off it starts shaking like crazy. and sometimes i cant put it into second or third and wen i do it grinds.
Sounds like the problem is in your ignition system.
Inspect your ignition wires, and dizzy cap/rotor. If you can't remember the last time you changed them, change'em.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigkvn77 »</TD></TR><TR><TD CLASS="quote">Sounds like the problem is in your ignition system.
Inspect your ignition wires, and dizzy cap/rotor. If you can't remember the last time you changed them, change'em.</TD></TR></TABLE>
I think that's it... check that cap and rotor.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BinMop »</TD></TR><TR><TD CLASS="quote">lol, ok so i just use the seafoam today, new boshe platinum spark plugs, oil change, and it still does it, i read the CEL code again today and it was 71 72 73 74, all 4 random misfire cylinder!!? whats my problem???</TD></TR></TABLE>
as an aside. bosch plugs are trash.....go spend 8 bucks more and buy some ngk's
bosch + honda = no no
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">
bosch + honda = no no</TD></TR></TABLE>
X2
Just spend the extra cash
X2
Project_Civic
Apr 3, 2005 05:07 PM
