Which TIG welder?
Old Oct 26, 2007 | 11:25 PM
xxbulaxx's Avatar
Default Which TIG welder?
What would be a good entry-level TIG setup? Looking for something capable of doing mild, stainless, and aluminum. Scratch start capable, but also with a pedal. It doesn't need to be something rediculous...I only want to be able to do automotive type work. So I'm sure 150-180 amps is more than enough. What do you recommend?
Old Oct 26, 2007 | 11:47 PM
ManBearPig4silly's Avatar
used miller 180 sd (or older) should be under 1000 with all the goodies attached.
Old Oct 27, 2007 | 03:14 AM
ROTARY's Avatar
and save your cash until you can buy the biggest argon tank your LWS will sell you.
Old Oct 27, 2007 | 07:16 AM
fastboy559's Avatar
Default Re: (ROTARY)
syncro wave 200 super nice nice machine welds aluminum amazingly almost holds a perfectly shart tip on aluminum apit pricy just get it with out the pulser and it shouldnt be to bad
Old Oct 27, 2007 | 09:01 AM
The Destroyer's Avatar
Default Re: (fastboy559)
Im having the same dilemma. So far new iv looked at the hobart tigmate/miller econotig. Thats about the most I want to spend and I like the idea of a warranty. Anyone have either of these, I know someone mentioned the tigmate in another thread.
Old Oct 27, 2007 | 10:12 AM
Justin Olson's Avatar
Default Re: (The Destroyer)
Save a little extra money and get a awesome inverted power supply. This is what I have and love it. Only weighs 38 lbs, and doesn't draw more then 30amps at full tilt.
http://www.weldingsuppliesfrom...etail
Justin
Old Oct 27, 2007 | 05:26 PM
terr1bleone's Avatar
syncrowave 180s weld real nice, id try and shoot for one with a water cooled torch if your doing car work. i personally like the lincoln 350 square wave, the years with digital readout and dials for controll instead of full digital pushbutton. id look on ebay, i seen a few around us with watercoolers for around a grand.
Old Oct 28, 2007 | 10:41 AM
xxbulaxx's Avatar
Default Re: (terr1bleone)
That sounds like a nice deal. Watercooled would be nice just to keep the duty cycle up...Not having to stop if I don't want to sounds nice.
Old Oct 28, 2007 | 05:54 PM
CSaddict's Avatar
You can buy a Thermal Arc 185 for right around $2k new. I love mine.
Old Oct 29, 2007 | 09:06 AM
m R g S r's Avatar
Default Re: (CSaddict)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CSaddict &raquo;</TD></TR><TR><TD CLASS="quote">You can buy a Thermal Arc 185 for right around $2k new. I love mine.</TD></TR></TABLE>
from cyberweld a sync 200 is 1800 or so....
this guy on weldingweb.com called weldersales....people have had good experience with him, sells the sync 200 for (i think this is what he quoted me) 1300
abnaasefmb
Welding / Fabrication
Jan 2, 2010 09:21 AM
twkdCD595
Apr 7, 2005 06:18 AM
parasonic
Feb 2, 2005 06:13 PM
Anthonyl469
11
Aug 16, 2004 07:35 PM
ion_four
Nov 6, 2002 10:47 AM
