help..91 si dont start.
well i check everything from main relay it works the fuel pump.. i get fuel... i get sparks no CEL.. for some reason my car wont start.. it turns.. my starter work.. alternator works... still no life on the car
i got the car like that..i mean.. ignition is ripped out but i used another ignition..it cant be the replay i replace it with a working one. cant be the fuses i check all of them.. i check cap and dizzy i get sparks but for some reason it wont start. starter works fine. i still dont get it to start..i get fuel in the injectors.
i would say i dunno.. cause the guy i bought it from said before the car got stolen it was running. so i assumed it will run. just put in new bat new relay and another ignition..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnoobie »</TD></TR><TR><TD CLASS="quote">i would say i dunno.. cause the guy i bought it from said before the car got stolen it was running. so i assumed it will run. just put in new bat new relay and another ignition.. </TD></TR></TABLE>
Assumed lol, please check hte motor to see, if its got fuel + spark (as you indicate) All you need is air and compression to make it run. Something has to be off in th timing or firing order.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by efnoobie »</TD></TR><TR><TD CLASS="quote">ILL CHECK THE TIMING.</TD></TR></TABLE>
and grounds
and grounds
JDM Freakk
Jun 21, 2011 05:36 PM
coot_er
11
May 7, 2005 08:54 PM
Accord15
Jun 25, 2003 09:54 AM
