b18 wont start, cel 8
Old Oct 26, 2007 | 09:08 PM
usdmed9's Avatar
Default b18 wont start, cel 8
I've got a 91 crx si with a 94 ls motor in it. Most of the time it starts and runs fine but sometimes (esp when its cooler temp outside) it wont even crank and give me cel 8 for tdc sensor. I've had this problem with the ls that was originally in it and i just recently replaced it with one from HMO. My question is what could be causing this since it happened with two different motors and distributors. I have a "preformance" ecu that came with the car and i kind of think that is what is causing my problem.
Old Oct 26, 2007 | 09:46 PM
loudandlow's Avatar
Default Re: b18 wont start, cel 8 (usdmed9)
you asked a question you already know the answer to
get a stock ecu and quit f*cking around.:whack:
Old Oct 26, 2007 | 10:22 PM
usdmed9's Avatar
i wasn't sure if that would cause that or not
Old Oct 26, 2007 | 10:46 PM
loudandlow's Avatar
Default Re: (usdmed9)
that would be your next course of action. let us know how it turns out!
Old Oct 26, 2007 | 10:49 PM
dkrex001's Avatar
did you check that te wiring is fine
Old Nov 7, 2007 | 05:24 PM
usdmed9's Avatar
well i put in a stock pr4 ecu and known working starter and it's still not even cranking when its really cold outside
HondaStufff
24
Jan 17, 2019 01:19 PM
pimpwagon
Jan 4, 2014 10:20 PM
Junior1023
Oct 22, 2013 10:38 AM
timisyourfriend
Feb 8, 2007 09:41 AM
Blaze45
12
Jul 3, 2003 02:07 PM
