how to remove fenders
94 and up their are the bolts under hood, also remove front bumper. Then you have to remove the bottom plastic piece that runs the side of the car to get at 2 more bolts on the bottom. Dont force anything.
4-10mm bolts under the hood.
Remove the wheel and the fender liner.
10mm bolt toward the front of the fender inside the wheel well. Right behind your headlight. It connects the fender bracket to the fender.
Remove small plastic screw tabs on the side skirt. To remove the side skirt you have to slide it forward.(toward front of car) *tip: Always found it easier to get it to budge if you hit it with a rubber mallet on the rear. (not too hard)
This exposes 2-10mm bolts at the bottom of the fender right infront of your door. remove those.
Open the door and inside the crack of the door (where the hinges are for the door) there is another 10mm bolt. That is the last of the bolts. Leave the door open and remove the fender.
Its the same for both sides.
avstar26
Apr 22, 2009 10:28 AM
