Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Brake Indicator
Old Oct 26, 2007 | 04:54 PM
Floopale's Avatar
Default Brake Indicator
Okay, so I'm on my way back from college and my brake indicator light comes on. I checked the fluid and its at nearly a perfect level, the pedal doesn't feel any less firm to my knowledge and I'm not hearing any random noises. I'm generally very kind to my brakes and barely use them at all to begin with. I'm just wondering if anybody out there has had a similar experience and can let me know what they did about it or if its that serious, cuz obviously being in college I don't have immediate access to a stealership
Old Oct 26, 2007 | 04:58 PM
fg2si!kid's Avatar
New User
Default Re: Brake Indicator (Floopale)
check you pad level both sides of caliper and rears too ,you didnt forget to put your e brake down did you ?
Old Oct 26, 2007 | 05:01 PM
Hellzcivic's Avatar
If it is your SRS light, then you need to go to the dealer and get an update to your ECU. When I was at the dealer last week they told me about this update.
Good Luck
Old Oct 26, 2007 | 05:34 PM
fg2si!kid's Avatar
New User
Default Re: Brake Indicator (Hellzcivic)
SRS (safety restraint system ) your air bags
Old Oct 26, 2007 | 09:25 PM
Floopale's Avatar
Default Re: Brake Indicator (fg2si!kid)
nah its not the SRS and I didn't leave the e-brake up...but it is the same light....i doubt its my pads but i'll check on that....i was thinking about reseting the ECU and seeing if the problem persists.....any opinions on this option?
Old Oct 26, 2007 | 09:32 PM
fg2si!kid's Avatar
New User
yea you could try that dont see why it wouldhurt it might not come back on right away you may need to drive around for a few miles to make sure
how old is the car ? (year)
Old Oct 27, 2007 | 10:07 AM
BlaqkAudio's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Floopale &raquo;</TD></TR><TR><TD CLASS="quote">nah its not the SRS and I didn't leave the e-brake up...but it is the same light....i doubt its my pads but i'll check on that....i was thinking about reseting the ECU and seeing if the problem persists.....any opinions on this option?</TD></TR></TABLE>
I know you said you didn't leave the e-brake up, but make sure the handle is all the way down. Once I accidentally brushed my leg against the handle making it go up just a bit, not enough to engage the e-brake, but enough for the brake light to come on.
Chilly56
Nov 23, 2019 08:46 AM
redacura
Dec 6, 2008 04:53 PM
xTurtle714x
Nov 28, 2004 01:57 AM
98type_r
Jan 3, 2003 01:41 PM
TurboTurtleGSR
Sep 23, 2002 08:53 PM
