Hello all,First post with some questions.
I have a 86 accord that i just put a 89 engine in.It had less than 30,000 miles with all receipts for maintanance.I also put in a new clutch,brakes,exhaust and efi.It runs like a new car now.I have a bearing in the passenger side knuckle that is a little loose and need a source for tools.I need a hub puller and tie rod and ball joint tools.Anyone have a good source for reasonably priced tools.Thanks Mark
you dont need tools for the ball joints or tie rod ends, just smack them with a hammer good and hard. might not seperate at first, but a few good blows will do the trick.
I have tried that with no luck,maybe i need to use my sledge hammer.I don't want to tear up the knuckle or anything else just to replace a coupe parts.
Mark
Mark
no, dont use a sledge, thats too much, a nice 4 lb hammer will do... standard hammers are too light...
your other option is a pickle fork, but i prefer not to use those because they tear up boots and bushings...
Thanks Hammer99EX,I cheated and put a large chisel between knuckle and lower piece and poped them apart.my 24 oz ball peen worked on the rest.Took about 30 min a side to remove them from the junker i have.
Thanks again Mark
Thanks again Mark
PandaBear
Suspension & Brakes
Jul 22, 2006 08:26 AM
2000Accord5sp
Nov 20, 2002 08:00 AM
