Need help B18C1 into my 97 EJ
Hey can anybody help me? I have a 1997 EJ dx and I blew my engine I just got
an offer on a B18C1 and I want to get it but i was searching trhoug the forums
and I can't find step by step procedure can anybody help me?
the more important questions I have are
1why can I use the GSR wiring harness?(I read because civc use on piece to chassi
but I was wondering don't they have and adapter for that insted of buying an adater for and obd2a to obd2b
2 add wiring for the VTEC Solenoid (VTS) & VTEC Pressure Switch (VTPS)
3 perform the IACV mod
4 add wiring for the Knock Sensor (KS) - IF - using an OBD2 DOHC VTEC ecu or non-reprogrammed OBD1 DOHC VTEC ecu
i got a 97 ex and put a gsr in it, i kno i have an ex harness but its a only a few wires diff, everything in mine plugged up no problem, so ur best bet would be to add w.e wires you need or just grab a diff harness
I have the same car you do only that mine is a hatchback. It's pretty easy. Hard part is gathering the correct parts. For wiring you'll need the 96-98 EX harness has to be manual transmission compatible if your car is a 5spd. Get the Si rear mount, driverside mount, and tranny mount. You'll need 94-01 integra intermediate shaft and axles, and the b series shift linkage. Oh, and a b series transmission too. Also get an obd2 p72 gsr ecu. That's about it. After you get all those parts, search around here and you'll find how to swap it.
chrisnick
Sep 10, 2014 03:13 PM
savestheday13x2
Jul 15, 2004 10:50 PM
