Front sway bar question
Old Jun 21, 2002 | 03:34 PM
lopey's Avatar
Default Front sway bar question
I have a 00 gsr with an itr rear sway bar out back. I was wondering if there was any benefit in getting an itr front sway bar installed in my car. Will it fit?
Old Jun 21, 2002 | 04:03 PM
nfn15037's Avatar
Default Re: Front sway bar question (lopey)
No need, both use the same size front sway, well, for the USDM. But to answer your question, the ITR front bar will fit if you really want to, but be warned, front swaybar install is a pain in the ***!
Old Jun 21, 2002 | 04:21 PM
kkim's Avatar
Default Re: Front sway bar question (nfn15037)
could you elaborate? cliff notes explanation would be fine. what all is involved in changing the front sway?
thanks
Old Jun 22, 2002 | 08:16 AM
lopey's Avatar
So they are the same diameter? (itr vs. gsr front sway bar) Would getting a trunk brace be a better suspension mod than getting an itr front sway bar?
Old Jun 22, 2002 | 01:01 PM
nfn15037's Avatar
Lemme say this again, GSR AND ITR FRONT SWAYS ARE THE SAME. So, yes, a trunk brace would be better than a ITR front sway, but i wouldnt worry about that little bar across the rear. Get a rear tower bar if you wanna buy a bar. Just my $.02.
null.
Aug 7, 2004 12:03 PM
fastfu
Jun 8, 2004 04:02 AM
V-Grip! Teknic73
Nov 12, 2002 05:02 PM
mamaboy
Nov 17, 2001 06:49 AM
