acura 2.5tl blower motor
would anyone know where the location of the ac / heater blower motor for a 1996 model? I don't have any heat and it's getting cold outside :-)
I know it's under the dash / behind the glove box but I can't seem to locate it.
thanks........pics or detail replacement instructions would be great!!!!
you dont have to remove the dash to replace the blower motor. it come's out the bottom from the blower motor housing 3 screws and some clips. here is some info
Modified by dtapia at 10:47 PM 10/28/2007
Blower motor essentially just quit working. Banged on the dash a couple of days and it would start blowing but since has just quit all together. Replaced the control module (the item on the dash that changes from heat to a/c, etc.) with no success. Tried replacing the blower motor but couldn't locate it so I put it back together and it started working again. So it either had a loose connection or I just temporarily "fixed" it, not sure which. I kept the blower motor guessing that it'll quit again soon. Any suggestions?
thanks...........
Paul 270.997.0211
thanks...........
Paul 270.997.0211
It quit again this past week so I hard wire the blower motor directly to the cigarette lighter and it appears to be working fine, although it's on "high" the whole time. But on high is better than not on at all. Makes me think the relay switch is bad but I really don't have any idea.
johnclaunch
Sep 8, 2004 10:59 AM
jester
11
May 18, 2003 12:09 PM
