T1 tuned 465.9 whp
Old Oct 26, 2007 | 10:07 AM
gunslinger's Avatar
From: Where thieves get shot in the face,, texas, usa
Default T1 tuned 465.9 whp
Well I dont usually post this kind of stuff but I thought I would share.
Set-up
b18c1 block is untouched
ARP studs
Gsr head
Skunk2 valvetrain(springs and retainers)
Type-R Cams
Full-Race Topmount
sc6152e
3inch T1 DP
walbro in-tank and external bosche 044
1000CC PTE injectors
stock trans
T1 tuned on E85
run
.10 is 6lbs
.11 is 8lbs
.12 is 11.5lbs
.13 is 15lbs
and last run .14 is 17lbs 465.9WHP
the motor
here is the car
Old Oct 26, 2007 | 10:29 AM
FastCougar's Avatar
Default Re: T1 tuned 465.9 whp (gunslinger)
I have the same turbo and was wondering if you have a dyno plot vs. RPM? I have a 3L V6 intead of an 1.8L I4, so it will differ I'm sure, but will give me some indication as to when boost will come on.
BTW, nice clean Honda there and great numbers for conservative/mid boost
Old Oct 26, 2007 | 10:31 AM
Schister66's Avatar
Man U FTW
nice...the more and more i see great results with E85, the more i want to retune my GSR on it...im waiting for a built engine first
Old Oct 26, 2007 | 10:33 AM
gunslinger's Avatar
Default Re: T1 tuned 465.9 whp (FastCougar)
Dyno rpm pick up was dropping out so no sorry
Old Oct 26, 2007 | 10:36 AM
Schister66's Avatar
Man U FTW
i just noticed that this is a stock block...wow
maybe i will just toss in some 880cc injectors, ITR cams and go for broke
Old Oct 26, 2007 | 10:38 AM
maxxd97's Avatar
Default Re: (Schister66)
I wish we had E85 around here...I would get retuned in a heart beat! Car must be a blast to drive!
Old Oct 26, 2007 | 10:40 AM
FastCougar's Avatar
What was done to the fuel system to allow E85 to be used? IIRC, Flex Fuel vehicles use a different type of rubber tubing???
Old Oct 26, 2007 | 10:54 AM
gunslinger's Avatar
Default Re: (FastCougar)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastCougar &raquo;</TD></TR><TR><TD CLASS="quote">What was done to the fuel system to allow E85 to be used? </TD></TR></TABLE>
None
Old Oct 26, 2007 | 11:02 AM
FastCougar's Avatar
Default Re: (gunslinger)
Sorry about that ... I mistook ethanol with methanol ... E85 is no more corrosive than regular gasoline.
Old Oct 26, 2007 | 11:20 AM
dpetro1's Avatar
nice looking car and setup. what amount of power are you running on the street? im sure you dont want that much hp on stock block for any more than a dyno pull or two.
Old Oct 26, 2007 | 11:29 AM
Drew Peacock's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FastCougar &raquo;</TD></TR><TR><TD CLASS="quote">Sorry about that ... I mistook ethanol with methanol ... E85 is no more corrosive than regular gasoline.</TD></TR></TABLE> Are you sure? Don't you need to flow more of it to get the same kind of A/F ratios as well? Nice result.
Old Oct 26, 2007 | 11:32 AM
BoostedJeff's Avatar
Default Re: (Drew Peacock)
Awesome power for stock block! T1
Old Oct 26, 2007 | 11:38 AM
dreadcivicturbo's Avatar
nice...honda motors are the best
Old Oct 26, 2007 | 11:43 AM
.CUBISH.'s Avatar
Default Re: (dreadcivicturbo)
nice!!.. pump worked out good for you i see
Old Oct 26, 2007 | 11:58 AM
gunslinger's Avatar
Default Re: (.CUBISH.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .CUBISH. &raquo;</TD></TR><TR><TD CLASS="quote">nice!!.. pump worked out good for you i see </TD></TR></TABLE>
Yes sir thanks
Old Oct 26, 2007 | 12:00 PM
gunslinger's Avatar
Default Re: (dpetro1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dpetro1 &raquo;</TD></TR><TR><TD CLASS="quote">nice looking car and setup. what amount of power are you running on the street? im sure you dont want that much hp on stock block for any more than a dyno pull or two. </TD></TR></TABLE>
Well boost is by gear 7lbs in 1st 14 in2nd and 17 in3-5
Old Oct 26, 2007 | 04:48 PM
boogerbum's Avatar
nice numbers
Old Oct 26, 2007 | 07:49 PM
stealthmode62's Avatar
Default Re: (boogerbum)
Nice setup. What did the base fuel pressure and duty cycle end up being?
Old Oct 26, 2007 | 08:05 PM
boostismycrack's Avatar
E-thug
Very nice car and setup man, any track times yet?
Old Oct 27, 2007 | 06:10 AM
blackeg's Avatar
Default Re: (boostismycrack)
power curves look like a supercharged motor imo...
very nice numbers for a stock block!!!
Old Oct 27, 2007 | 06:16 AM
SovXietday's Avatar
Default Re: (blackeg)
Power increase is really weird? Nice numbers though.
Old Oct 27, 2007 | 06:47 AM
red_crx's Avatar
Power band looks good...props for you and T1 .
Old Oct 27, 2007 | 07:05 AM
boosted k20's Avatar
looks like the car wants to rev more, powers is not fall n off! build the bottom end and rev that thing higher. Good numbers
Old Oct 27, 2007 | 07:34 AM
Boosted B6teen's Avatar
Default Re: (boosted k20)
Great numbers man. I will be re-tuning on E85 this upcoming summer, cant wait.
Hope you have fun with it
Old Oct 27, 2007 | 07:49 AM
ZacCarter's Avatar
Default Re: (Boosted B6teen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted B6teen &raquo;</TD></TR><TR><TD CLASS="quote">Great numbers man. I will be re-tuning on E85 this upcoming summer, cant wait.
Hope you have fun with it </TD></TR></TABLE>Nice Numbers Billy.
