Auto tranny shifting late!!!
Old Oct 26, 2007 | 10:04 AM
midnitesol's Avatar
Default Auto tranny shifting late!!!
Ok i just did my first auto swap ever and now it seems like it takes too long for it to shift gears . Is there a way to adjust that? Thanks ahead of time for your help! Oh its a 95 ex with a d16 if it matters.
Old Oct 26, 2007 | 01:30 PM
playskool's Avatar
Default Re: Auto tranny shifting late!!! (midnitesol)
are you using the 5 speed ecu? cause that will make your upshifts later
Old Oct 26, 2007 | 03:02 PM
Syndacate's Avatar
Default Re: Auto tranny shifting late!!! (playskool)
Sounds like the governor valve is sticking - not sure if you can service that - if not, it's gotta be replaced.
Old Oct 27, 2007 | 03:18 PM
midnitesol's Avatar
Default Re: Auto tranny shifting late!!! (Syndacate)
No im using an auto ecu and where is the governor valve located?
Old Oct 29, 2007 | 01:23 PM
midnitesol's Avatar
Any other input?
Old Oct 29, 2007 | 02:35 PM
Magik123's Avatar
governor is located in the valve body, could also be the throttle position sensor usually get a MIL for that, check ur ATF level/color thats some of what i would check at least for the easy stuff
Old Oct 30, 2007 | 09:52 AM
midnitesol's Avatar
Default Re: Auto tranny shifting late!!! (Magik123)
Cool thanks will try. Any one else?
qcty_jdmes1
Honda Civic (2001 - 2005)
Oct 15, 2009 02:41 PM
bonies
24
Aug 30, 2009 11:00 PM
spectacle
Apr 10, 2007 09:53 AM
StraightCivic
Jun 8, 2005 11:47 AM
zojirushi
Nov 8, 2001 03:26 PM
