car wont park when cold
i have a 91 integra GS auto and whenever its cold outside the tranny wont shift into park, i have to wait until the park light appears until i can remove the key from the ignition...ive dealt with this problem for consecutive winters, ive done searches but no real solution....
Well, temporary solution= Put it in neutral, take the key out, put it in the gear slot thing, and put it in park...
But I don't see why cold weather would cause that???
all my gears are lined up, i should mention that the engine idles rough as it sits in the park position and i cannot remove the key until the park light comes on, so therefore it would be impossible to remove the key and stick it in the gear shift override
i dont know why cold weather is causing it either
how do i fix/lubricate the linkage?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Byaaah! »</TD></TR><TR><TD CLASS="quote">Well, temporary solution= Put it in neutral, take the key out, put it in the gear slot thing, and put it in park...
But I don't see why cold weather would cause that???</TD></TR></TABLE>
You can't take the key out until the car is in park.
I had the same exact problem in my 91 GS, I read somewhere that it's some issue with the electrical contacts in the gear selector. Search around on http://www.G2IC.com, I think someone had a fix for it there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GRAF-FITI »</TD></TR><TR><TD CLASS="quote">try replacing the NEUTRAL SAFETY SWITCH
i don't know whats wrong with me...that's like my 5th "helpful" post today
i made this post like 3 months ago, since then i did a motor/tranny swap....no more problem...
</TD></TR></TABLE>i made this post like 3 months ago, since then i did a motor/tranny swap....no more problem...
TPHGraphics
Apr 18, 2006 08:05 AM
