Forced Induction Everything Forced Induction (Ex: Turbo Kits, Intercoolers, Blowoff valves, IC Piping, Turbo Manifolds)
Tial Wastegates and BOVs!
Old Oct 26, 2007 | 05:29 AM
velocitytrends.com's Avatar
Default Tial Wastegates and BOVs!
<FONT COLOR="red">Velocity Trends</FONT> <FONT COLOR="blue">is holding a clearance on all Tial products. We have a bunch of Wastegates and BOVs laying around that we want to get rid of.</FONT>
Please PM me, AIM me at <FONT COLOR="orange">VelocityTrends1</FONT>, email me at noah@velocitytrends.com, or call me at the shop at <FONT COLOR="green">904.997.9903</FONT> for the HONDA-TECH PRICE!
<u>Tial 38mm Wastegate</u>
- 347 Stainless Steel Alloy is used for valve and valve housing.
- High temperature silicone Nomex reinforced actuator diaphragm.
- 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resists "relaxing" at temperature to 900F (483C).
- Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing the same material used in the higher level gates for reliability and longevity.
- CNC Machined 304L 12mm thick weld flanges.
- Low Cost.
- Made is USA.
- Color anodized 6061-T651 aluminum actuator (Silver, Red, Blue, Purple, Black).
- Wastegates shipped with air fittings and stainless hardware.
- Flanges are an extra cost, they do not come with the wastegate.
<u>Tial 41mm</u>
- High temp NiCrFe based alloy is used for valve and 347SS valve housing will offer longer product life compared to competing designs.
- 17-7 PH Stainless Steel actuator spring gives consistent pressure at high temperature, resist "relaxing" at temperature to 900F (483C).
- Nitronic 60 Stainless Steel is used for the valve seat, and valve bushing.
- All Stainless Steel hardware.
- Mating weld flanges are 304L.
- Color anodized aluminum actuator (Black, Red, Blue, Purple).
<u>Tial 44mm</u>
- Color anodized aluminum actuator (Silver, Red, Blue, Purple, Black).
Flanges can be included also for an additional small price.
<u>Tial 50mm Blow Off Valve</u>
- For use on turbo-charged and super-charged applications (Paxton, Vortec, etc.). The body and all internal components are CNC-machined from 6061 aluminum alloy. It features a large 1.98 in (50.5mm) valve; we believe this is the largest valve available with the highest flow capacity.
- The V-Band design aluminum mounting clamp gives a very clean and unique appearance. The clamp is anodized and uses Stainless Steel hardware for a long lasting, corrosion-free appearance.
- The valve seal utilizes a Viton O-ring that is clamped in place to prevent the possibility of sticking to the seat and pulling out. The valve stem and guide are Teflon-lubricated, hard anodize-coated for wear resistance.
- The Blow Off Valve also comes with our own machined aluminum banjo-type air fitting and bolt, with over sized 10mm hose barb for quick actuator response. The actuator has a high temp silicone Nomex-reinforced diaphragm for long life.
- An aluminum or mild steel weld base mounting flange is furnished with each unit. Stainless Steel is available at an additional cost. The use of 6061 aluminum allows the housing to be anodized with a selection of colors where most cast aluminum alloys can not be anodized. This allows the individual to match, or coordinate, the engine compartment color scheme. The clamp, valve, and housing will be offered in Silver, Black, Red, Blue, and Purple to allow you to mix or match the clamp, body, and valve assembly to create a look unique to your application. You may also purchase a plain or unassembled unit to anodize or color-coat as you like.
I can do combo packages with any of the products for an even cheaper price. All items are instock and ready to go so no waiting weeks for them.
Modified by velocitytrends.com at 10:08 AM 10/26/2007
Old Oct 26, 2007 | 06:15 AM
civic121978's Avatar
Modified by civic121978 at 8:13 AM 10/26/2007
Old Oct 26, 2007 | 07:04 AM
Default Re: (civic121978)
Store/Site has a promo code for special pricing.
Old Oct 26, 2007 | 09:11 AM
All PMs replied to.
Old Oct 26, 2007 | 10:06 AM
Laz's EP's Avatar
Default Re: (velocitytrends.com)
Pm me a price on a Tial 44mm wastegate.
Thanks
Old Oct 26, 2007 | 10:25 AM
PMs sent.
Old Oct 26, 2007 | 11:57 AM
vpsunworks's Avatar
bump
Old Oct 26, 2007 | 01:04 PM
PMs replied!
Old Oct 26, 2007 | 05:05 PM
NoahD's Avatar
Vrooom pssshsh!
Old Oct 27, 2007 | 05:56 AM
Bump for Saturday.
All PMs replied to.
Old Oct 27, 2007 | 11:03 AM
Keep em coming.
Old Oct 28, 2007 | 06:42 PM
velocitytrends's Avatar
Default Re: Tial Wastegates and BOVs! (velocitytrends.com)
Give us a call or pm us and see for yourself.
Old Oct 29, 2007 | 04:58 AM
Old Oct 29, 2007 | 10:53 AM
TTT- YYEEEAAHH!
Old Oct 30, 2007 | 04:53 AM
Bump for awesome prices.
Old Oct 31, 2007 | 05:07 AM
Good morning America!
Old Oct 31, 2007 | 06:09 PM
Bump.
Old Nov 1, 2007 | 05:33 AM
Morning everyone.
Old Nov 2, 2007 | 05:31 AM
TGIF.
Old Nov 2, 2007 | 12:49 PM
TTT.
Old Nov 4, 2007 | 06:37 AM
Orders taken. PMs replied to.
Old Nov 5, 2007 | 06:12 AM
Bump.
Old Nov 5, 2007 | 11:17 AM
Orders shipped.
Old Nov 6, 2007 | 04:45 AM
Vroom psssh.
Old Nov 6, 2007 | 12:45 PM
BIZUMP!
