Help! CRX B16 Harness Dilemma (NOOB)
Old Oct 25, 2007 | 11:10 PM
exist12's Avatar
Default Help! CRX B16 Harness Problem (NOOB)
Im about to install a b16a into my DX crx. I've read about a few guys cutting up their stock DX harness but i also heard that i could use an SI harness for wiring. i have a spare SI harness but is it just plug and play? Any advice would be appreciated, this is my first swap obviously.
Modified by exist12 at 1:11 AM 10/26/2007
Old Oct 26, 2007 | 05:43 AM
Spaceballsthelunchbox's Avatar
No Big Whoop
Default Re: Help! CRX B16 Harness Problem (exist12)
This qustion is as old as Honda-tech. Tons and tons of posts about it, do a search, but there are a few notes.
DO NOT use an SI harness, will not work, period.
You need two things.
1. convert to MPFI, using the si harness as a donor.
2. convert the harness to VTEC using the B16 harness as a donor.
Do a little reading/searching all the info you need is here.
Old Oct 26, 2007 | 08:17 AM
jdm_titan's Avatar
Default Re: Help! CRX B16 Harness Problem (Maxbore.com)
X2
Old Oct 26, 2007 | 08:19 AM
prettylew's Avatar
or you could just completely convert to OBD1 like i did. engine harness and dash harness
Sosa0311
Sep 15, 2012 11:14 AM
91CRX-T
Aug 17, 2011 01:16 PM
BlendedEM1
Feb 13, 2011 07:06 PM
ikaika3269
10
Feb 26, 2008 06:25 PM
dwchkypmp20
11
Dec 10, 2003 03:57 PM
