need some help!!
hello,
i have looked through my service manual and searched for it. could someone help me identify two plugs. Any and all help will be appreciated.
thanks a lot bill
these two plugs are under the dash on the drive side
Modified by wbaldwin_86 at 10:27 PM 10/25/2007
thanks a lot bill
no i dont think so... i bought the car from the insurance company with no motor. now i am trying to start it and the fuel pump will no turn on and the car wont crank over. no i am going trough all of the wiring to see if anything is missing and found these two plugs
i think those plugs go to the turnsignal/headlight/wiper assembly
for fuel, check if you have a fuel main relay, its going to be above the hood latch , its a gray box with a brown plug(7wire)
for crank/start, cehck the clutch safety switch , whatever its called, its going to be located on the clutch pedal assembly up top, pretty much its a on/off switch, make sure its pressing the button when u step on the clutch if not, fix it, to test it just jump the plug/connect to the 2 wires
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civichx1998 »</TD></TR><TR><TD CLASS="quote">I believe the top picture is in the Haynes manual look at page 12-22 or 12-23.... its for the Starting system.</TD></TR></TABLE> alright i will look it to that thanks a lot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ironcheftony »</TD></TR><TR><TD CLASS="quote">i think those plugs go to the turnsignal/headlight/wiper assembly
for crank/start, cehck the clutch safety switch , whatever its called, its going to be located on the clutch pedal assembly up top, pretty much its a on/off switch, make sure its pressing the button when u step on the clutch if not, fix it, to test it just jump the plug/connect to the 2 wires</TD></TR></TABLE> hmm will look in to it also thanks a lot
SiR Inspired ED7
May 21, 2007 07:08 PM
