obd1 conversion problem, code 41 oxygen sensor
Old Oct 25, 2007 | 06:15 PM
nickel168's Avatar
Default obd1 conversion problem, code 41 oxygen sensor
guys, i'm having a problem with my obd1 conversion everything seems to be ok, except that i keep getting a code for the 02 sensor, so I changed the 02 sensor resetted the ecu, still comes up with the code. The obd jumper that i'm using came with the car when i bought it, I think it's an ebay one, anybody has any input? I also tried adding a ground to the 02 sensor, which didn't do anything either. any help is appreciated. thank you
Old Oct 25, 2007 | 08:21 PM
Fezzie's Avatar
Default Re: (Dustin_Pierce)
check and see if there is any breaks in the o2 wires, in the harness
Old Oct 26, 2007 | 06:26 AM
peanut butter's Avatar
Default Re: (Fezzie)
It's easy to get the wires mixed up on the o2 sensor. Switch them around until the code goes away. Don't forget to reset the ecu each time!
Old Oct 26, 2007 | 06:29 AM
IT GUY's Avatar
Default Re: obd1 conversion problem, code 41 oxygen sensor (nickel168)
what O2 sensor are you running?
Old Oct 27, 2007 | 01:22 PM
nickel168's Avatar
Default Re: obd1 conversion problem, code 41 oxygen sensor (IT GUY)
i'm using a 4 wire integra sensor. I tried all of the above no luck. ..any more suggestions?
Coltmorris
20
Mar 8, 2009 08:42 AM
vtec25
Mar 14, 2006 02:39 AM
BeavisB16
Apr 29, 2005 03:57 PM
GSlowR
Dec 2, 2004 06:33 AM
wizzards581
Mar 22, 2004 07:31 PM
