my massive garage sale including gsr block. crank. and any other gsr engine part
Old Oct 25, 2007 | 06:05 PM
SoSlo's Avatar
Default my massive garage sale including gsr block. crank. and any other gsr engine part UPDATED
GSR BARE BLOCK(NEEDS WORK bore and deck)____________________________________$offer
GSR MAIN CAPS WITH GIRDLE_____________________________________$40(sol d)
OBD1 GSR DIZZY COMPLETE_______________________________________$80 (sold)
b18c crank (need to be polished has 1 spun rod bearing)_______$25
GSR OIL PAN_______________________________________________ ____$40(sold)
B SERIES KNOCK SENSOR_________________________________________$40
B SERIES COOLANT TEMP SENSOR__________________________________$30
B SERIES OIL PRESSURE SENSOR__________________________________$30
99 GSR OIL PUMP______________________________________________ _$30
99 GSR WATER PUMP_____________________________________________$ 20
GSR INTAKE MANIFOLD BRACKET___________________________________$5
99 GSR WATER TUBE AND THERMOSTAT HOUSING______________________$25
type-r rear sway brackets(new in package)_____________________$15
blue eg back seat_____________________________________________$ 15
92-95 climate control_________________________________________$1 5
black power window controls___________________________________$10
black small side dash defrost vents___________________________$5
painted red small side dash defrost vents(faded)______________$2
painted red passenger side vent(faded)________________________$5
black interior door handle trim_______________________________$10
painted black interior door handle trim(some small chips)_____$5
driverside black speaker cover________________________________$5
blue rear seatbelts_________________________________________ __$10
blue front seatbelts_________________________________________ __$10
both speaker covers(covered with black fabric)________________$10
b series oil pickup___________________________________________$ 15(sold)
b series idler pulley(used)___________________________________$5
b16 tranny brace_____________________________________________ _$5
obd2 crank angle sensor_______________________________________$15
obd 2 timingbelt crank pulley(chipped)________________________$5
obd 2 timingbelt crank pulley_________________________________$5
obd 1 timingbelt crank pulley_________________________________$15
vx (13/16) brake master cylinder______________________________$5
gsr crank pulley____________________________________________ __$25
3 usdm gsr pistons with wrist pins____________________________$10
2 jdm gsr pistons with wrist pins_____________________________$5
drive side eg manual mirror___________________________________$5
srs computer__________________________________________ ________$15
ls crank case breather box____________________________________$10
gsr crank case breather box___________________________________$10
gsr engine header bracket_____________________________________$5
black charcole box____________________________________________$5
5 bolt turbo exaust flange____________________________________$10
2.5"-3" turbo coupler_________________________________________$5
2.5" t-clamp_____________________________________________ _____$5
3" t-clamp_____________________________________________ _______$5
92-95 oem headlights (one bracket broken)_____________________$10
obd1 coolant temp sensor(block)_______________________________$5
b series coolant thermostat housing and tube__________________$15
4 oem b series wrist pin______________________________________$5
picks on request
<FONT SIZE="18"><FONT COLOR="red">everything is OBO</FONT> </FONT>
IF YOU DONT LIKE MY PRICE THEN OFFER SOMETHING
THINGS I NEED ARE:
LS RODS STOCK OR AFTERMARKET
DUAL VALVE SPRINGS FOR A B SERIES
81MM RINGS
i am paypal certified
hit me up at smmccurdy@hotmail.com
Modified by SoSlo at 4:15 PM 10/28/2007
Old Oct 26, 2007 | 06:51 AM
moridin2004's Avatar
Default Re: my massive garage sale including gsr block. crank. and any other gsr engine part (SoSlo)
pm'd
Modified by moridin2004 at 5:12 PM 10/27/2007
Old Oct 28, 2007 | 01:01 PM
SoSlo's Avatar
Default Re: my massive garage sale including gsr block. crank. and any other gsr engine part (moridin2004)
replied
Old Oct 28, 2007 | 02:54 PM
akmi_1's Avatar
FREE BUMP...MIGHT NEED SOME STUFF...
