Am I lacking anything people? freshening up a B16A swap....
Old Oct 25, 2007 | 05:39 PM
stockbee's Avatar
Default Am I lacking anything people? freshening up a B16A swap....
What's up guys/gals?
I am in the process of accumulating the last few parts I need for the reinstallation of my old 1st gen. B16A that was in my '89 DX that I used to have, into my new(er) '90 Si. Either way.
Here is what I have, followed by what I realize I'm lacking to make these particular upgrades work. Your all's job is to read this and let me know of anything that I've forgotten to mention, or get. Thanks in advance.
Have:
-Engine
-Rebuilt Y1 tranny (LSD equipped)
-P28 ECU
-OBD1 GSR Distr.
-OEM Honda Cap and Rotor replacement
-Rywire OBD0-OBD1 conversion harness
-Axles (O'Reilly's, weak, but they'll do)
-ARP headstuds
-Supertech Valves (oem sizing, flat faced)
-OEM Honda Upper Head Gasket kit (head gasket,exhaust,intake,etc.)
-OEM valves seals (as mine were getting bad in a almost 20 year old head).
-ITR Intake manifold
-ITR Throttle Body(map and tps included)
-Skunk 2 Pro Series (cam gears)
-OEM VTEC solenoid gasket
-STR billet cam seal
NEED:
-To replace my LMA's as they are clicking when VTEC isn't engaged (EXPENSIVE)
-4-wire O2 sensor
-New Main Relay (as mine is starting to give me trouble lately).
-Timing Belt
Christmas is coming and I'll be getting Full Race traction bars most likely so those will open up space for a good 4-1 header. Till then I just need to get things going.
I'll probably keep using the same water pump and oil pump. However I would like to trade someone for a B16A timing belt as I have a GSR one I won't be using that is brand new and in the package.
Thanks for the help.
Old Oct 25, 2007 | 05:47 PM
Tippyman's Avatar
Default Re: (Dustin_Pierce)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dustin_Pierce &raquo;</TD></TR><TR><TD CLASS="quote">what headgasket you are going to use?</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stockbee &raquo;</TD></TR><TR><TD CLASS="quote">
-OEM Honda Upper Head Gasket kit (head gasket,exhaust,intake,etc.)</TD></TR></TABLE>
Old Oct 25, 2007 | 06:07 PM
stockbee's Avatar
lol, 3 layer.
Old Oct 25, 2007 | 06:15 PM
Tippyman's Avatar
And blow out easier.
Shaving the head and/or block will achieve the same result, get a better seal, and give you a nice headgasket.
Besides, it's not like honda offers diffent layer headgaskets, you just take layers out of the stock one to make a ghetto compression bumper.
Old Oct 25, 2007 | 06:50 PM
stockbee's Avatar
Thanks for the advice guys. I've got the headgasket what's next?
I was checking out your build thread today tippyman, it's looking good.
Old Oct 26, 2007 | 12:22 AM
STREETWERKZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dustin_Pierce &raquo;</TD></TR><TR><TD CLASS="quote">1 layer, 2 layer or 3 layer head gasket. honda has these options. </TD></TR></TABLE>
no.
Old Oct 26, 2007 | 07:14 AM
stockbee's Avatar
haha. Any more advice guys.
Old Oct 26, 2007 | 08:43 AM
prettylew's Avatar
have you done the rear main seal yet? if the motor is already out u may as well do it. seal cost like 16 dollars and takes literally 10 minutes to do with the motor already out. when normally u need to drop the motor and remove the trany clutch and flywheel.
and when it leaks it SUCKS lol. oil EVERYWHERE
Old Oct 27, 2007 | 03:31 PM
stockbee's Avatar
Good suggestion "prettylew"!
You're referring to the seal behin the oil cooler am I correct that is just a big o-ring? If so, I had to replace that while I was in school at florida one time.
I realized an oil smell and saw my car smoking at a stoplight and knew something was up. It was messy for sho.
Old Oct 27, 2007 | 08:19 PM
Tippyman's Avatar
Default Re: (stockbee)
It's the seal on the block inside the tranny case.
Old Oct 27, 2007 | 08:21 PM
stockbee's Avatar
gotcha. thanks for setting me straight on that one.
Old Oct 29, 2007 | 01:15 PM
stockbee's Avatar
monday bump.
Jaydeep
24
Aug 5, 2013 09:43 PM
lcsej1
10
Feb 18, 2009 11:23 AM
eg6cusco10pt
May 31, 2004 10:14 AM
