Wheels, Tires, Brakes, and Suspension Wheel, Tire, Brake and Suspension Parts (Wheels, Tires, Coilovers, Lug Nuts, Camber Kits, Rim/Tire Tools)
*********** T1R Suspension In Stock! **********
Old Oct 25, 2007 | 03:52 PM
Gump's Avatar
Default *********** T1R Suspension In Stock! **********
T1R Suspension products in stock. For pricing and inquiries about other coilover applications please give me call or send a PM.
Darryl
T1R Front Anti-Bumpsteer kit - Honda S2000 00-07 AP1 AP2
Do you ever notice how your wheel tugs when driving over un-even roads at high speeds on a lowered S2000? The angle on the steering tie rod has changed due to the lower ride height from coilovers or lowering springs..etc. The factory has designed the steering system to be optimized at the stock height. It takes very little angle in the wheel to make the car steer. The T1R bumpsteer kit returns the steering tie rod to the more optimal and to create stock-like suspension angle. Recommended for S2000 whoch lowers 1-2.5 inches. Made out of CNC machined Forged 6061 aluminum with anodized coating against rust of oxidation. Race proven performance.
T1R B-Max 52 Damper - Honda Fit 07-up GD3
Comfort and Performance normally is not a combination you can find from most of the suspension available the market. T1R offers 46mm piston MONOTUBE tube design for maximum dampening ranges for street and track. T1R also offers camber, 36 way compression/rebound, ride height/stroke and spring preload adjustable for wide range suspension setting and tuning. Made out of CNC machined chromoly steel built for heat dissiapation and to reduce unsprung weight. Comes with aluminum uppermount (Optional pillowball uppermounts), adjust wrenches and necessicity hardware for installation. SAE9254 Cold forming springs are equipped with the damper kit.
T1R B-Max 52 Damper - Honda S2000 00+ (AP1/2)
Specifically designed for Time Attack (Best lap) purposes. 46mm piston mono-tube for wide tunability ranges. Features 36 way compression & rebound single adjustable. Track proven performance. Made out of spacecraft CNC machined chromoly steel built for heat dissiapation and to reduce unsprung weight. Comes with high tension pillowball uppermount, adjust wrenches and necessicity hardware for installation. SAE9254 Cold forming springs are equipped with the damper kit.
Old Oct 26, 2007 | 11:56 AM
Gump's Avatar
Default Re: *********** T1R Suspension In Stock! ********** (Gump)
Old Oct 29, 2007 | 10:09 AM
Gump's Avatar
triple7
Aug 7, 2008 07:22 PM
gsr16
Honda S2000
Jun 29, 2005 07:52 PM
Luke
Honda S2000
13
Apr 6, 2002 01:44 AM
